Convergence replaced convergence chip and resoldered tower...convergence fine on tv portion...watching tv its fine. the problem is that svideo..composite and dvi stilll have convergence issue. is there a seperate board or fuse or chip that would cause this? will try to manually set covergence again. any help is appreciated
  • 8,617 Answers
Sounds like your talking about an RCA HD rear projectio n if so the convergence defaulst will all have to be set and saved for each format. I can assist with info on how to do that if you send me a email to slinteriors@yahoo.com I can email the instructions they are too large to post here properly
Posted on Jan 02, 2013
johnnydiode
  • 647 Answers
SOURCE: Replaced the fuse in RCA R52wm24 and resoldered
The fuse blows when there is aproblem with the convergence board - if the TV just had issues with the convergence b4 you soldered and replaced the fuse then the set should not be dead - I would check all plugs especially the 2 flexible (short) cables that jump the (ssb) two boards together. Do you hear the HV trying to start (a little chirp sound near the flyback) If so the set is in shutdown mode if not then power supply problems are usually the cause - check for swelled capacitors in power supply.
Posted on Oct 06, 2009
Testimonial: "Amazing how you can pinpoint an issue by reading text from someone who has no idea what they are doing! Great job! It was one of the two flimsy cables"
ladywinn
  • 5138 Answers
SOURCE: R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Posted on Nov 13, 2009
Ecollier2012
  • 3459 Answers
SOURCE: "convergence chip failure"
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
  • 4 Answers
SOURCE: WS-55909 convergence problem turns now into F9A04 Fuse issue
I had this happen on my WS55909 about 2 years ago. I dont remember what the circuit id's for the fuses were, but out of 6 fuses on the middle board, the two in the middle were blown. I traced the circuit schematic and found that only the convergence IC could cause these fuses to blow. It sounds like you already put in a new convergence IC (the one with the big-*** heat-sink which probably also needs a fan) but you need to make sure all those fuses on that board are still good. After I replaced that IC, my TV still didn't work. I went and double checked for continuity of all the fuses on that board and one was blown (after checking all of them and replacing the IC). Replaced it and the TV has worked ever since. Total repair cost was 23 bucks. Professionals recommended that I would be better off just buying a LCD TV than fixing my rear projection TV, but I still dont think you can get one of those as big as 55" for only 23 bucks! ****. BTW, mitsubishi would probably tell you otherwise, but you don't have to use those "littlefuse" fuses. I soldered in a fuse-holder for a glass fuse of the same value (5amp 125v in my case) that can be purchased at radio shack. A fuse is a fuse. My TV never burst into flames.
Posted on Apr 09, 2010
electronick
  • 505 Answers
SOURCE: SONY KP-65WS510 TV LOOKS LIKE TYPICAL CONVERSION
there are fuses on each driver (6 in all) under the heatsinks usually.. make sure these are good. there are also 2 5amp fuses on the g board that supply power to the chips + and - 24volts.. check both of these.. i've seen some check good in circuit and still are bad, check voltage to see for sure. In a rare case, i knocked off a small surface mount resistor when unsoldering the chip, and then the convergence was muted.. make sure no small surface mount parts were moved on the bottom of the board when you soldered. good luck, let me know wif you need futher assistance.
Posted on Jun 19, 2010
Testimonial: "I APPRECIATE YOUR ASSISTANCE. IT GOT ME IN THE RIGHT AREA, THE FUSES WERE GOOD, BUT THERE WAS A BURNED SOLDER RUN COMING OFF ONE OF THE FUSES. THE SET WORKS GREAT NOW. THANKS FOR YOUR HELP."
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
May 04, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
How can i watch movies from computer to my tv
You probably need to get a composite video output card for your computer. Actually, I've seen many cards that have both a composite video output AND a DVI output port on 1 card. The DVI output will give you a noticeably sharper picture than composite video, but you need to check if your TV has a DVI or HDMI input. (If it was manufactured after 2000, it probably does.) If you TV was manufactured after 2006, it probably has 1 or more HDMI inputs instead of DVI. You can buy a DVI to HDMI converter cable. That takes care of the picture; to get sound to the TV, you will need to connect separate sound cables to your TV. Your computer needs to have a line-level output jack on it's sound card, and you will need to get an adapter cable (from Radio Shack) to convert the stereo mini-plug to 2 RCA type plugs to plug into your TV. And that should do it!
Dec 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
How do I connect my Sony viao to my philips LCD
If your PC has a DVI port( ihope u have one) purchase a DVI cable and connect it to your TVs DVI port
DVI port
dvi cable
If your tv has no DVI port and only VGA port buy a vga cable and dvi to vga converter and connect to pc and use it
vga cable
you can also get a svideo to avi converter cable and use it to connect to your tv
svideo converter
Nov 27, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
I HAVE A ZENITH TELEVISION AND I CANNOT HOOK MY DVD/VCR COMBO TO IT. THERE IS NO PLACE TO PUT THE CABLE. MY TELEVISION HAS THE ANTENNA/CABLE PLUG AND THE YELLOW,WHITE,AND RED OUTLETS ON.
your TV has composit video in but your DVD/VCR only has Component video and Svideo outputs ..those are not compatable with your tv .. if you look more closely you might find an SVideo input on your tv .. its flat and not as easy to see as the normal jacks .. if your tv does have SVideo then all you need is an SVideo cable (plus the two sound cables) ... i could check on what you have if you give the TV model number .. othwise you have to have something to convert your SVideo to composit video .. there is a cable that does that .. you can check with radio shack .. if they do have such a cable then one end would plug into the svideo of the dvd/vcr . the other end would plug into the yellow jack on your tv .. hook up sound and it should work ok ..
here is such a cable on the internet ..
http://www.cablestogo.com/product.asp?cat_id=2012&sku=27964#tab=review
or google "svideo to composite" to see lots of options
Nov 22, 2009 | Sylvania DV220SL8 DVD Player/VCR
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Tv looks fine when playing movies or Tv but looks all teac blue when using xbox360
Depending upon the signal, perhaps the convergence is off all the time, just not seen. If you can solder, try resoldering the convergence IC pins. Let me know if there is any change.
Thanks,
Dan
Sep 24, 2008 | Sony KP-51HW40 51" Rear Projection...
JVC AV-56WP74 Problem
Yes, one of your convergence IC's have gone bad. They are located on the convergence board inside the tv and there are two of them. They are inexpensive and easy to replace if you know how to solder. Watch out for the JVC booby trap sensor on the dvi input card. Don't run the tv with the back panel off unless you have disconnected the DVI card from the main board. I would even cover the little sensor with black electrical tape. Then it is safe to work on the tv when it's open and on. Well safe for those who know what they are doing.
Jul 29, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
