Question about Coleman Mach 15 Air Conditioner
We have a coleman mach it does air and heat as well as gas when we turn it to electric if it goes to the top ceiling is that heat --it goes to where the gas comes on is that gas when we have it on heat
  • Coleman Master
  • 6,674 Answers
What do you have for an RV that this is installed in?
Posted on Jan 28, 2013
5 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: problem with heat pump
This sounds like a 4--step furnace. Step 1 ,the small ven fan turns on and proves it turnning thru the small air tube that sucks a switch close . Step 2 the spark igniter lights the pilot ...Step 3, the main gas valve opens up and dump gas in the venture tubes to heat the box up, Step 4 theres a swith in the box the when heated closes and turn the fan on! Thank-you-very-much!
Posted on Aug 28, 2008
koolbreezes
  • 540 Answers
SOURCE: coleman mach air
Time for a spring cleanning,, especially the drainnage system, filter,, front cooling coils-and the drain line! thank you-very-much!
  • 5 Answers
SOURCE: Coleman unit, no heat or air, only fan runs.
check for wiring & compresor
Posted on Apr 06, 2009
  • 127 Answers
SOURCE: coleman mach chill grill - heat turns on whether
Sounds like you have a bad thermostat or a short in the wiring. The clicking that you are hearing in the ceiling is a relay in the control board. When this happens, remove the face plate from the thermostat and check for 12VDC between the Blue and the White wires. If there is power then you have a bad thermostat. If there is not power there, then the problem is elsewhere. However, it sounds as if you have a bad thermostat.
Posted on Jul 04, 2009
Thermostat
If this is a park model trailer like mine, there is a transformer in what they call the ceiling package. It is mounted up inside the return air plenum.
Jul 31, 2013 | Coleman Mach III Air Conditioner
Coleman Mach III RV AC
Sounds like possible fan capacitor failure. If your not familiar with capacitors, please find someone who is, as they can give a fatal electrical jolt if not handled properly.
Jan 26, 2013 | Coleman Mach III Air Conditioner
Need fan switch for coleman a/c model 6734B917
Any RV dealer should be able to get you one, if not try inquiring here.
http://www.rvcomfort.com/rvp/contact.php
May 24, 2012 | Coleman Mach 3 Plus Roof Mount A/c Unit W/...
Need printed circuit board for coleman 8333-8715 need part number have 115 vac to board but no out put
Is that # off upper unit or ceiling assy? Need ceiling assy # Here's a link for you to try.
http://www.rvcomfort.com/rvp/service/model.php
Jul 12, 2009 | Coleman Mach III Air Conditioner
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Coleman mach chill grill - heat turns on whether we have it programed or not. have heat off, ''I feel'' off, can be 80 outside we can be gone and come back to 110 degrees inside and heater on. When it...
Jun 03, 2009 | Coleman Mach 15 Air Conditioner
Problem with heat pump
Aug 18, 2008 | Coleman Mach III Air Conditioner
Coleman Mach 15 Air Conditioner Logo
47 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
