Question about Skytech Smart Stat Fireplace Remote for Heat-N-Glo
Fireplace remote not working properly - Skytech Smart Stat Fireplace Remote for Heat-N-Glo
    New Friend:
  • 72 Answers
Jim,
I'm not sure if you have found a solution to your problem yet, but if you would like to provide some additional information about your problem, I'd be happy to help.
If you are looking for a replacement, I have them available here: Smart Stat Remote for Heat-N-Glo.
Posted on Jan 21, 2013
Connect wires properly
Yes, you SHOULD connect all the wires properly.
Your should also ASK YOUR QUESTION PROPERLY!
Come on, man. Get with it.
You are asking how to connect wires to a remote control?
Someone dropped you on your head as a child, yes?
Fireplace? Don't play with fire.
Mar 05, 2015 | Skytech 1001-A Fireplace Remote Control...
Gas fireplace remote wont turn on the fireplace new batteries have been inserted with no result
If you want to check if your remote is working and you have a cell phone that takes pictures hold the remote in front of the camera and when you have a pitre of the remote press the button and you see it on the camera if you don't the remote is not working hope this helps (this goes for all remotes ) Tom
Nov 20, 2014 | Real Fyre 24" Forest Oak Ventless Natural...
Remote not work
May not be the remote-can you turn on the fireplace manually ? May be electronic ignition for fire place.
Dec 09, 2013 | Televison & Video
Remote won't work unless next to fireplace.
There are some adjustments that can be made to improve the reception of the Skytech 3301 Fireplace Remote.
Sometimes the RF reception can be diminished if the receiver is in an enclosed metal surround such as a heat shield.
The link above will bring you to the product page where you can scroll down and download the full owner's manual. An excerpt from the manual in regards to adjusting the reception is below:
"RECEIVER ADJUSTMENT - RECOMMENDED ADJUSTMENT
NOTE: The slide button, Gray or Black, covers the ADJ access hole when installed.
A. To adjust at the receiver, use a small slotted screwdriver. Turn the adjustment screw counter-clockwise
about 5 degrees or a maximum of 1/8 turn. This should correct the distance problem.
B. If that does not correct the problem, return adjustment screw to original position and then turn adjustment
screw clockwise.
This adjustment is like tuning your radio. If you keep turning the adjustment screw, in either direction, you will go past the proper setting (tuning)."
Dec 25, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Cant start gas fireplace
  • Find the remote's receiver under the fireplace.
  • There should be a switch to change from "remote" to "ON".
  • Turn the switch to "ON", if the fireplace ignites, you may need to re synchronize your remote. If it does not, your remote control may be bad.
  • Bypass the remote to ensure your fireplace is operational by connecting the "TH" and "TP/TH" terminals on the valve with a wire or paperclip. If the fireplace lights up fine, then it is for sure a bad remote.
  • Universal gas fireplace remotes can be found HERE.
Oct 28, 2012 | Empire Comfort Systems Empire Tahoe...
The remote no longers turns on the fireplace.
  • Is your valve turned "on" and not in the "pilot" mode?
  • If your valve is in the "on" position, try turning the Skytech receiver's switch to "on" instead of remote.
  • If the fireplace ignites when the receiver is "on" then the remote needs to be re-synchronized.
  • If the fireplace valve is "on", the remote's receiver is in the "on" position, and the fireplace will not light, then you most likely have a bad thermopile in your fireplace and need service.
  • Skytech 1001-A product page and manual can be found here.
Dec 09, 2011 | Skytech 1001-A Fireplace Remote Control...
Receiver was beeping all the time. I changed batteries in receiver, and now remote does not control fireplace. Remote appears to be working fine. If I move switch to on instead of remote on receiver, it...
If you changed the batteries in the receiver (the black box in the fireplace). You should also change the 2-batteries in the hand-held remote. This may sound stupid, but it's not ... be sure all the batteries in the receiver (black box) are all facing the proper direction. Believe me, it's easy to get one turned the wrong direction. Also, make sure that the slide switch is in fact in the remote position. It can be finicky at times. Also, check to make sure that the two wires are still connected firmly at the gas fireplace Control Valve and in the receiver.
  • Now, if all of that doesn't solve your problem, the receiver may have lost it's code..
When matching security codes, be sure slide button on the receiver is in the REMOTE position; the code will NOT "LEARN" if the slide switch
is in the ON or OFF position. Program the remote receiver to LEARN a new security code by pushing in the LEARN button on the top of the
remote receiver and then pressing the MODE button on the transmitter. A change in the beeping pattern, at the receiver, indicates the
transmitter's code has been programmed into the receiver.
There's a lot to check out and do, but that's how you trouble shoot these remotes.
Feb 03, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
My remote won't control the fireplace. Do you have to program it
Normally, it comes programed. Before trying to reprogram it ...First, be sure you have the leads from the black receiver box connected to the proper terminals on the control valve of your gas fireplace. Secondly, be sure ALL the batteries are installed properly (i.e. facing the right direction). Do you get a beep when you press the Mode button on the hand held remote? If you do, the problem is some where else.
If you gas fireplace has a rocker switch in the control compartment that was used to turn the burner on and off ... Is it a 2 position switch or a 3 position switch? If it's a 2 position switch, be sure it's in the ON position. If it's a 3 position switch, it should be in the middle position. Is the gas control valve knob turned from Pilot to the ON position? Is your Pilot Light burning? It has to be for the remote control to work.
To test the whether or not the remote is connected properly, push the slide switch on the front of the black receiver box to the ON position. If you pilot is burning and the control knob for the burner is in the ON position, the burner should then light. If it doesn't then I suspect the wiring from the black receiver box to the control valve is not connected to the proper terminals. Or a rocker switch is in the wrong position. If all this fails contact SkyTech Technical Service @ 888-672-8929.
Jan 10, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Soot on glass,outside vent and on walls of fireplace
you have a problem with combustion.unit is not burning properly you should turn unit off and call a pro the life you save may be your own
Apr 12, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Skytech Smart Stat Fireplace Remote for Heat-N-Glo Logo
356 people viewed this question
Top Skytech Home Security Experts
Lawrence Oravetz
Are you a Skytech Home Security Expert? Answer questions, earn points and help others
