Question about Cycling
I have schwinn sprint (ten speed) and don,t even know how to change gears and which gears are which. Also do you know where I can get a users manual (preferably for free) I have problems downloading o
Have a problem downloading manuals, so even if it costs, I will probably be better of ordering a user manual to be sent to me.
  • 21 Answers
Here is the Schwinn site with manuals:
http://www.schwinnbikes.com/support/owners-manuals
Here is contact information:
http://www.schwinnbikes.com/contacts
Good Luck!
Posted on Jan 06, 2013
  • 990 Answers
SOURCE: Need users manual for old Schwinn Airdyne - analog model
Sheldon Brown's Bicycle glossery is a good place to start, you can google him and he may be slow on replys but he can usally steer you in the right direction.
Posted on Aug 21, 2009
Testimonial: "I emailed Sheldon Brown. Larry"
SOURCE: How can I order a
ebay or bike shop i would. and try the place u bort it they mite have 1
Posted on Jan 22, 2009
agent91
  • 2100 Answers
SOURCE: how to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
Posted on May 03, 2010
  • 1788 Answers
SOURCE: Need free instruction manual for
Go to schwinnbike.com and you can download a manual for free. Make sure that you use metric wrenches because all bikes are metric. If, you bought from a bike shop, they will help you with what is needed.
Posted on Sep 15, 2010
dunnbiker
  • 8546 Answers
SOURCE: I need a 'free' downloadable
any particular one in mind?
You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
Posted on Jul 06, 2011
How to change the tire on a schwinn loop
It's pretty straightforward changing the tires on the loop. I'm a big guy and the standard 65 PSI tires it comes with are ****. two blowouts already in the rear, most likely due to poor weight distribution. But Whatever the reason you have, here's how to change the rear tire.
1. You'll need to grab a 15mm wrench or socket & ratchet combo. Remember, righty tighty lefty loosey.
2. Remove the rear derailleur gear guard, it just sort of falls off. Store it somewhere safe until you're ready to reassemble everything.
3. Gently pull upward on the wheel once both bolts are removed. Carefully pull the derailleur away from wheel gears as you pull it upward and out of the gear system entirely.
4. Done with that part and the wheel should be out! Do whatever repairs that are necessary for the removal of the wheel, possibly changing a tube, I don't know. You needed it out, now it's out.
5. Reassembly is easy enough. Make sure the wheel isn't fully inflated while reassembling. The brakes on the Schwinn loop are tiny little things, you'll need to pinch to get it past where it needs to be again.
6. Move the derailleur gears out of the way while you move the wheel back into place, then slowly remount the chain onto the wheel gear assembly. It's very intuitive, you'll see exactly what you need to do here.
7. Throw that rear derailleur gears guard back on there, screw on and tighten those rear bolts and bam! Presto change-o! The tire is changed and you can feel a little more mechanically inclined for the day.
NOTE: Changing the front wheel is also a simple job. You'll use the same 15mm tool, except there are no gears to worry about. Cheers!
Jul 09, 2012 | Pacific International Schwinn Loop 7-Speed...
1972 schwinn breeze 3 speed......was working well. Now first gear slips while I'm riding. Once in a while second slips.
re-grease everything, clean it all up, check all your cables and shifting mechanisms, see if that helps
Jun 26, 2012 | Schwinn Cycling
I need an instruction manual for a ten speed Schwinn bike. I just bought a used one and need to know how to shift into the various speeds.
There's nothing unique about an old Scwhinn that isn't available on the web.
"How to shift" or just about any question will summon resources instantly. Wear a helmet.
If you must have a generic Schwinn manual go to schwinnbikes.com
The Web. Answers everywhere.
Sep 03, 2011 | Cycling
How can I fix a schwinn 14 speed varsity back tire
You don't say what's wrong with it. Web search "fix (symptom) bicycle tire" or whatever you wish to know. Search engines work.
Aug 26, 2011 | Schwinn Cycling
How do I switch gears on the Schwinn Roxi Beach Crusier. I just bought it used and dont know how to swith gears?
Search engine "how to shift gears": or find the generic bike manual for Schwinns which can be found by searching for "schwinn bicycle manual". See how that works?.
Aug 17, 2011 | Cycling
Acquired a 1958 Schwinn World Sport Ten Speed (4130 Main Tube). Need an instruction manual. Don't know what the shifters are for.
If, I were you I would get a tune up on it and then ask the mechanic how to shift. It is too complicated to go into here. You can try googling instructions, but the book that came with it, really did not go into detail. I know I have been a Schwinn dealer since 1979. You always have to be pedaling forward to shift, do not pedal backwards, you can chip teeth off of your chainrings.
Apr 20, 2011 | Cycling
My Schwinn recumbent bike seems to be working in reverse. High is like pedaling air and low offers just a little resistance. What can I do?
What kind of gearing is on this bike..Can you post a pic?? If it is an integral geared hub then there may be issues with the inner workings. If it has gears like a ten speed then there may be a worn ratchet mechanism in the gear head?? not sure as your question is kind of vague..
Mar 20, 2010 | Cycling
How do I operate 10 speed road bike?Schwinn La Tour How do I change gears
the gear lever on the left controls the front derailleur which will have two different size sprockets...when you first start to ride you want it on the smaller of the two. The gear lever on the right controls the back or rear derailleur with a gear cluster of five small to increasing larger sprockets...when first starting to ride you want that on the largest one .....five in the rear and two in the front (5x2=10 variable speeds to chose from). as you increase speed slowly lift up (because this lever will be located down) on the right shifter to help maintain an even speed to help you go faster..when your on the smallest gear in the back and want to go even faster then pull down on the left shifter to go to the larger sprocket you are now in ten gear.When coming to a stop reverse the shift levers and repeat...if the chain rides off the sprockets when shifting especially in the front derailleur it means the shift guide is bent to far to one side or you derailleur needs adjusting same goes for the rear..there are two little screws stops with springs that you use to make these fine adjustments. My family owned a Schwinn shop, i was a mechanic for a good 12 years and i havent heard the name La tour in a long time i owned one myself and have a traveler still today. Tip..keep chain lubed, WD-40 will work fine, and also lube the gear cables with a light grease...also dont rotate the handle bars up for easier comfort because in an emergency stop situation all your weight will transfer to the brake levers and you fly forward over the handle bars.
Oct 02, 2009 | Cycling
How do you use the 21 speeds on the Schwinn ladies coaster bike?
there are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Sep 07, 2009 | Schwinn Cycling
Cycling Logo
253 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
