RCA flatscreen remote doesn't work
RCA remote doesn't work. It worked until I tried programming with a Direct TV remote. I couldn't get the Direct TV remote to work (none of the codes worked) and then the RCA remote quit working also. The remote flashes (it has new batteries) but the TV doesn't respond for anything including the power button.
  • 8,617 Answers
\its most likely the ir sensor which has the issue. I will need the model number of your set to help you further on the issue. You can reply to this same post for further assistance if needed.
Posted on Jan 01, 2013
  • Bob Kluk Jan 02, 2013
    Model Number is 32LA30RQ. 32" LCD RCA flat screen tv.
  • Sonny Berry
    Sonny Berry Jan 02, 2013
    i would suspect the IR sensor you should be able to get one by send a email request to customerservice@tvrepairworld.com include your model number and symptoms they respond quickly.
techman
  • 3130 Answers
SOURCE: remote control
The correct model number is iLO2600.. That remote is available at http://www.remotes.com CHEAP!!
Posted on Sep 05, 2006
dsacco86
  • 1077 Answers
SOURCE: Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Posted on Jan 12, 2009
dsacco86
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: can't program direct tv remote control to the tv
Try here:
http://www.twirp.com/en/index.php
Posted on May 23, 2009
  • 13 Answers
SOURCE: Mintek TV and Direct TV remote wont program
Try a code search, the method should be in the manual. If you can't get that to work then it's not possible to use the DirecTV remote.
If that's the case then get a learning remote.
Posted on Jul 30, 2009
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
REMOTE PROGRAM CODE FOR RCA D52W20
When I got Direct TV my TV would not program with the remote so I had to use separate remotes. That is what the Direct TV rep told me and now I have Time Warner and still have the same problem with one of the TV's. Hope this helps
Mar 24, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
SRP4004/27
Let's try to sort this out. You have a universal remote control which you want to use with your RCA TV. You turn on the TV, press and release the TV button on your remote, and enter an RCA TV code. You then press the ON-OFF (or POWER) button and the TV turns off. If not, you repeat the process with other codes until you find one that turns the TV off. If you are successful, you should be able to turn on the TV and channel up or down through all available channels in your area. If I am missing something, post a reply
Nov 16, 2012 | Televison & Video
What is the code to program an rca remote to an orion tv
They don't have codes for an Orion. However, if I guessed at compatibility, I'd try:
005
064
076
008
009
In that order. If that doesn't work, let me know and we can take a couple more guesses. The codes noted are all codes used by other Orion made brands.
Jul 06, 2011 | RCA 257003 Remote Control
I can't program my direct tv remote to my coby TFTV3225 TV. Don't have the right codes. Does anyone know the codes?
11531 is the code given by DirecTV for this model. To enter this code . . .
1. Slide the mode switch at the top of the remote to the TV position
2. Hold both the MUTE and SELECT buttons until the LED blinks twice
3. Enter the 5-digit code 11531
4. Test the volume and power buttons for correct operation with the TV
If the code does not work first time, try entering the code a couple more times. If it still doesn't work, also try code 11436. DirecTV do not list any other codes for your TV, so if they don't work, it's possible that the remote will not work with your TV. There is also a code search option which tries every code in the remote. If this doesn't work, the remote definitely will not work with your TV.
Please try the codes above and let me know if you need further assistance or the code search instructions. Also, remember to slide the mode switch back to the DirecTV position after you have finished entering the codes.
Regards,
BElectric
Apr 24, 2011 | Coby TFTV3225 32 in. LCD TV
Have RCA L32HD31R flat screen TV. Codes for DirecTV sat. service do not work for their remote. Do you have any additional codes for this TV?
Need 5 digit codes for Direct TV remote, not 3 digit. I have a RCA flat screen and tried all 16 codes as per instruction from online PDF manuel and none of them work for me either.
Jan 05, 2010 | RCA DIRECTV Satellite Remote Control
I have this RCA remote and I misplaced the guidebook.
You must first find out why the remote control is not working properly. These remote controls have been having problems with new batteries. The battery holder on the positive side need to be adjusted out to make sure its making contact with the batteries. This may be the reason the remote control is not working. After you find the problem with the functioning of the remote control you can go to the RCA customer support website http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1 find the codes for the components you want to use with the remote control. Use the codes to make the remote operational . This should be all you have to, if the remote control is working properly. If you cannot get the remote control to work properly, you can call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of the remote control and ask them for assistance with the problem. I hope this information help you with the problem you are having with your remote control. Thank you for using FixYa and have a nice day!
Apr 07, 2009 | RCA DIRECTV Satellite Remote Control
Input Selection without a Remote
On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
May 24, 2008 | RCA F27442 27" TV
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
