Question about Ovens
My stoves newhome EFa600H turns itself off at high temps. It's aprox 5 yrs old. Bought it second hand! help please??? SJ
The oven is second hand but i was assured it was in good working order. It was fitted by a builder who does kitchens all the time. It turns of after about 30 mins at anything above 170. The top gets really hot on the outside (where the knobs are). Please help?
  • 126 Answers
SOURCE: Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Posted on Dec 14, 2007
SOURCE: oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Posted on Jan 09, 2009
MNTECH
  • 1543 Answers
SOURCE: GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
Posted on May 07, 2009
SOURCE: My Stoves EFa600H inner glass recently shatterd
Hi Sorry- i do not how to do this BUT the eaxct same thing has happened to us! Cna i ask where you got the replacement glass, how much it cost and how long it took to deliver?
Thanks
Posted on Jan 27, 2010
  • 4 Answers
SOURCE: i have just moved into a new flat and no manual
Try here:
http://www.manualsonline.com/ex/thread/view/idThread/3088468
Posted on Jun 09, 2010
Frigidaire stove is about 12 yrs. old. My oven will not heat past 250 degrees and it takes along time to reach that temp. The stove never indicates that the preheat temp. is reached. This just started last...
Hello, welcome to FixYa.
If you can provide the complete model number (usually on inside of door frame or around the bottom door opening), I'll see what I can find for you.
There are many possible scenarios as I hope you can appreciate being this is a global repair site, even within' the Frigidaire brand so I'll need to clarify the make & model before moving forward.
Regards,
Macmarkus :)
Aug 14, 2011 | Ovens
I require a new rubber door seal for my electric oven stoves newhome efa600h. I cant find who stocks them
If you try www.buyspares.co.uk not sure if they do specific model but might do a universal seal for stoves
Feb 22, 2011 | Ovens
Instruction manual for stoves newhome EFa600H fan oven
hi Ali, do you have any photos for this cooker EFa600H? I need front of this cooker. because i have in my new home but i can't used this apliance because all numbers ale clean, someone clean this oven very very strong and remove all signs:)
cheers, marce
Oct 04, 2010 | Ovens
I have an Inglis stove around 10-15 yrs old. When
Yes you can but not the elements themselves
Nov 29, 2009 | Ovens
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Change time display on Newhome efa600h electric cooker
Try here:
Jun 15, 2009 | Thermador SC302T Electric Double Oven
Ovens Logo
130 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
