Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
My adapter is registered as inactive, but it is plugged in.
I never had any problems with my adapter before now. My computer was off, and I turned it back on. Usually it automatically connects, but it wasn't this time. I looked at the program it runs through and it said that the adapter was inactive, which usually only happened if the adapter was unplugged previously. So, I proceeded to unplug the adapter and plug it back in. Nothing happened. My computer didn't even make a sound like it had registered me unplugging and plugging in anything though the USB port like it usually did. The adapter has a light on it that, when working properly, flashes a bright green when in use. Now all it has is a dim green light that is barely noticeable. I've tried re-installing the software and that didn't work. I also made sure that it wasn't the particular USB port that it was plugged in, and every port works fine with other USB devices.
And in case it might have something to do with it my computer is a Dell Dimension E510 running Windows XP Media Center.
Any help would be greatly appreciated.
  • Anonymous Apr 09, 2009
    I have the same problem aswell, ive had the adapater for about 5 months now and its been plugged into my computer almost the whole time...recently...i decided to start using my lan cable instead of the wireless and i hadnt noticed it stop working untill i tried plugging it into my laptop a couple days ago. Now the green light doesnt light up at all, and the linksys software is telling me its inactive...i recently experienced a couple power outages..after that is when i think it stopped working.
    Problem Solver:
  • 6 Answers
Go to Start -> Control panel -> Network connections. Right click on your wireless device and click enable. It should work after that.
Posted on Jan 19, 2009
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
Oct 04, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My computer will not turn on at all. i have the charger plugged in, and it isnt even registering that i have it pluged in
Well, hopefully... the problem is related to the adapter. If your fortunate to have either a volt-meter or have another equal computer to plug the adapter into, then you will know if that is where the problem lies.
It could also be the connector (at the computer), or the power switch. Or, something more expensive internal...
Aug 18, 2011 | Toshiba Satellite A215-S7444 Notebook
Aloha, I plug the power cord into my computer and the end that actually goes into the comp sometime registers and changes and other times it doesn't. Right now I cannot user my Acer because my...
I'm assuming this a laptop computer and you are having problems with the AC power adapter jack. This is quite common. Often the solder connections securing the jack to the circuit board inside the computer crack, or the contact lugs on the jack itself break. If the problem is a cracked solder connection, the fix is a simple resoldering job (the primary expense is labor to get the board out for repairs). If the jack is broken, it can be replaced - it will be about the same as resoldering plus about $1-$5 for the part.
Sometimes the problem is a broken wire right at the plug on the AC adapter. If it is a standard plug, that can be replaced. If it is an unusual custom plug, you're stuck with replacing the adapter.
To prevent this problem in the future, always hold the plug when you remove it from the computer (never yank on the wire), be sure you insert it straight into the jack when you plug it in, and avoid off-axis stresses on the plug or the cable near the plug.
Jul 10, 2011 | Acer (56.04145.901) (5604145901) Power...
Card is inactive
You might want to make sure that your wireless adapter is enabled. Depending on what operating system you will need to go into your network connections area and enable it.If you have a laptop make sure that the switch has been turned on. It is usually located on the front side of the laptop.
Jul 24, 2010 | Linksys WPC54GS Wireless Adapter
PP_0.00 is on the display screen The till stays on and inactive no matter where the key is
This sounds like a Royal. That's my best guess since you haven't told me what you have. PP means there is a printer problem. Look for a paper jam or any other reason why the printer motor can't turn.
If anyone needs Royal cash register manuals, try here: http://the-checkout-tech.com/manuals/cashregisters/royal1.php
Jul 20, 2010 | Casio Parts Cash Register PC Desktop
Using Win 2000 on a laptop, Notebook adapter WPC54GV3 and a wireless-G Linksys router and up to date driver. Will not connect, inactive adapter.Do you have a solution ?
It says the adapter is inactive. That means the adapter is not detected by the Linksys utility. Try to unplug the adapter and plug it back in. and restart the computer. now check if iot says active. If not then open the device manager and check if you can see the adapter there. If not then the adapter is not detected by the computer.
Try to uninstall the adapter and reinstall it. Make sure that you have the CD of the adapter before you will uninstall it.
Apr 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
When I plug the power cable into the computer the computer does not register the chord and it will not charge
Probably is problem with adapter or cables from adapter to computer so i think firs check voltage from adapter.
Apr 03, 2010 | Toshiba Satellite A60 Notebook
My linksys card status says inactive will it say
The linksys card says iactive when it is not recongnised by the computer.
Unplug the card and plug it back in and check if that works
Click Here for more information about routers and network
Jan 15, 2010 | Linksys Wireless-G WPC54G 802.11g/b
Adapter becomes inactive shortly after plugged in
In this case try upgrading the drivers for the adapter.
If it is already the latest one , then upload the drivers from the beginning.
Nov 28, 2009 | Macsense AeroLite 802.11g 54Mbps USB 2.0...
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
360 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
