Question about Karcher K5.85 1850psi Electric Pressure Washer - -
Karcher hand crank removal
Hose drum hand crank needs to be removed
How do I open the front of a Meile W911 Front loader
remove soap draw, remove screws on left hand side(T20), open drum door, three 10mm bolts around drum, open filter flap and unhook black hose from flap if there is one, the bottom left hand corner sits on top of a metal clip to hold it in position just pull to remove,
Sep 18, 2014 | Washing Machines
Instruction to remove and replace cage bearing on husqvarna 055 chainsaw.
I guess we are talking the bearing in the clutch drum, to replace this you need to remove the side cover nuts and remove the side cover/chainbrake, make sure the brake is de activated by pulling the hand guard fully back to the top handle before removing it, the clutch has a 15mm centre nut, jar the clutch off against the compression of the saw with a suitable socket and speed brace, if you have an impact wrench this will remove the clutch in seconds, the clutch is just spun onto the crank with a left hand thread, turn clockwise to remove, once off the drum and bearing will just come off the crank for replacment.
Oct 05, 2011 | Husqvarna Garden
Auto chain oiler not working
To remove the pump, start by removing the two 19mm bar nuts, remove the side cover, bar and chain, remove the c clip on the end of the crank, now remove the clutch drum, you now need a special tool to remove the clutch, part no, 530031112,the clutch is just spun onto the crank, left hand thread, the tool fits into the two cut a ways in the clutch centre and allows you to jar it off against compression, once removed there are just two screws retaining the pump assembly, check both gears for wear, you can now also pry out the oil pick up tube.
Feb 26, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
How to change the oil pump and line on a Husqvarna 455 Rancher
Ok, start by removing the side cover/chainbrake,the guide bar and chain, there should be just two 13mm nuts holding the side cover on, if you have tooless adjustment there will be a single flip up lever to remove the securing nut, you now need to remove the clutch, there are two slots cut into either side of the clutch centre, these slots are designed to take a screw driver ( preferably the combi tool that came with the saw ) you can then jar the clutch off against compression by striking the end of the screw driver with a suitable hammer, the clutch is just threaded onto the crank, left hand thread, so comes off clockwise, once removed you can pull the clutch drum and bearing off, remove the single 4mm allen screw from the silver bar protection plate and remove the plate, you will now see the oil pump, held with one allen headed screw, the delivery hose will just lift off, the pick up hose and filter will come out of the oil tank once the pump is removed.
Feb 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
MY DRYER IS NOT GETTING HOT IN THE INSIDE BUT THE OUTER BACK SIDE OF THE DRYER IS
Is your drum turning? Sounds like blower has stopped working. Or vent is plugged.
Lets check blower. Remove big exhaust hose. Now see if air is blowing out hard. DON'T put your hand in hole. If air is flowing blower is okay. So check the hose may need cleaned. Hopefully Hose is blocked.
Always unplug before removing any covers.
May 17, 2010 | GE DVL223EBWW Electric Dryer
NEED TO REPLACE REAR BEARING.GOT A NEW BEARING.NEED A DIAGRAM ON DISSASSEBLE,REPLACEMENT AND REASSEMBLE. OR SOME HANDS ON ADVICE....THANKS ..TY
really tedious job. if you are really keen, pl. follow.
remove motor, remove shoker top pins, remove top stone, remove all hose connecting drum, remove heater/other connections, remove door gasket from front, support drum from top, remove springs, lower drum, dismantle drum in two pieces, remove inner steel drum.
well rest i think you can think yourself.
Oct 30, 2009 | LG WM-0532HW Front Load Washer
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Hotpoint aquarius mwa42
Unscrew and remove lower rear cover of washer.
On the bottom right hand side, you will see the pump located, it has 2 hoses going to it.
Remove both hoses, unplug wires going to it, and slide the pump to the left, it may or may not have a fixing screw at bottom,remove pump and check.
If you need to check the filter, then remove large black hose going to bottom of tub, remove plastic filter ,and clean
Refit filter and hose, and test.
Plz rate my solution.
Thanks.
Jan 16, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
CLUNKING NOISE - SOMETHING TRAPPED BETWEEN INNER & OUTER DRUMS?
Yes, there is something trapped between the inner and outer drum, you could try removing the sump hose from the bottom of the drum, this will give you more room to fish about than possibly removing the heater. If you do remove the heater, you may not get it back in, then you will have to fit a new one.
The sump hose is the large hose fastened to the bottom of the outer tub.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Karcher K5.85 1850psi Electric Pressure Washer - - Logo
46 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
