Question about Samsung 50 in. Plasma TV
Can not turn off and volume turns down by it self changed batteries in remote
  • Samsung Master
  • 8,617 Answers
Need more info to assist you with the issue. Does the tv work except the volume turns down by itself even with the batteries removed from the remote? If so its either the Tact switch for the vol down has an issue or the main board has an issue. If the remote wont work the tv properly either or not at all too then i would say the main board is causing both conditions. If you require further assistance please let me know.
Posted on Jan 01, 2013
3 Suggested Answers
  • 718 Answers
SOURCE: my samsung le32r74bdx remote control wont change
You can verify that the remote is working. Get a digital camera with a LCD display.
Aim the remote at the camera lens and press the volume and channel buttons. If you do not see
a flash through the camera the remote is bad or the batteries are dead.
If you know someone with any samsung hdtv remote, you can borrow it and try the volume/channel
to see if the tv remote receiver is good.
Posted on Feb 08, 2011
djromann
  • 158 Answers
SOURCE: I have a 32 inch Samsung LCD TV. For some
Warning! Pull out the cord first!!! Open the TV take the tester and check over the mini board with the buttons, there might be the Vol- button in shortcut, or get some water. If its short, must replace, if there are water/ liquid/ oxyds traces, take a toothbrush, put a little of alcohol, and gently clean the place, after that dry it with a hairdryer.
Posted on May 18, 2011
Model PLDED6535A-UHD volume turns its self up to full volume an Won't stay down when I control it to a softer level. I replaced the batteries in the remote and it didn't help
The chip that controls volume settings is fubar. Try to reset the electronics to factory defaults and cross your fingers.
Sep 22, 2017 | Televison & Video
Volume will not turn up and will automatclly turn it self down when tv is turned on the volume bar is also pink
Take the battery/s out of the remote and operate the TV manually, if this works then its the remote itself causing the problem. Sometimes the buttons get stuck down and you need `flick` them with yor finger nail to release them. If the remote is quite well used then it needs taking apart and cleaning the contacts with a cotton bud and a non solvent cleaning fluid, this takes about 20 mins.
Also to test if the remote is transmitting, face the remote at a digital camera, if you can see a light or flickering in the viewer then you know its working everytime you press a button. If its flickering without touching it, at least one button is stuck down.
May 28, 2014 | Televison & Video
Volume, device inpute issues
Try new battery's in the remote, and check all volume buttons, one may be stuck down.
Mar 23, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Volume turns down by itself until it says VOLMIN
I have a Samsung home theater system model HT-D6730W. I have had some issues with the volume turning itself down till it says volmin. I've seen that I'm not the only one with this issue!!!! I have tried all the suggestions that were posted. Doing a hard reset, changing settings, I bought a cooling pad for laptops Hopi g those would fix it. I called Samsung support Which was a joke!!! I took the putter cover off and cleaned all the dust from the unit, removed batteries from remote, removed all cable connection on the back of the unit other than the HDMI cable going to the tv. Having done all that the unit was still turning its self down. I'm a bit of a tinker and so while the cover was off of the unit, displaying all the delicate stuff inside, I turned on the home theater system and played a movie set the volume to a good listening sound. When it started to turn it self down I remove the wide wire ribbon from the main circuit board going to the touch panel on the front of the unit. Voila!!! Sound quit going down!!!! I unplugged unit and removed front touch panel and cleaned all dust from the inside of it. Put it all back together. Tested. Still doing it. Removed the touch panel again and this time I disconnected the small wire ribbon for the volume touch buttons. Reassembled and tested. NO MORE ISSUES!!! Everything on the front still works other than the volume buttons. You can still change the volume using the remote!!!! I hope this finds everybody that is having this issue with there unit.
Feb 14, 2014 | Samsung Audio Players & Recorders
My 19in lcd hdtv emerson wont stop turning the volume down by its self.And then i took my batteries out of the remote and it is still doing the same thing. i cant even press buttons on the remote. Also...
See if the minus volume button on the TV is stuck. With the TV off press the various buttons while keeping your ears close to them. Each will produce a distinct click when you press them, confirm if the volume - key also produces the same sound - if not the key is defective or stuck.
Jun 02, 2011 | Emerson LC320EM8 32 in. LCD TV
Panasonic tv turns volume down by its self
there might be something wrong with the tv remote. turn the tv on then make it on a high volume then put the remote in a different room and see if the volume turns down if it doesn't then you have some thing wrong with the remote not the tv.
Jan 15, 2011 | Panasonic PT-50LC14 50" Rear Projection...
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
HELP
little gremlins in your flat panel
batterys in remote could be low or the volume button from factory sticks every now and then and says hey im going to mess with you today
or its controlled sound on the circuitry that has a signal interupt lead that when a signal interferes it turns it down its self
May 09, 2008 | Televison & Video
Samsung  50 in. Plasma TV Logo
85 people viewed this question
Jerry Greenberg
Jerry Greenberg
