Question about RCA F25654BC 25" TV
Blurred words when i look at my directv guide or any words it is very blurred and hard to read
    Sergeant:
  • 227 Answers
I have a hard time to vision that it is just the words, is the picture blurred also? If you are inclined, you have to take the back cover off. With a medium to small INSULATED screw driver you will see a big transformer that has a HIGH VOLTAGE lead going to the picture tube. There should be one or two black plastic screws on it (hence the insulated screw driver use) adjust one or the other to see if picture improves. Will not take much adjustment, but must take CAUTION as not touch the metal part of the screw driver, we are talking 15 to 32K volts. Naturally the tv has to be on to do this.
Posted on Jan 18, 2009
What fused number uses for fan blower
heater fan fuse. in dash blower. front not the rear OPTON
hard book to read, BMW, (lost in translation from German?)
A32m1 Blower motor
the right relay fuse box.
the Germans use codes instead of words for parts.
making the drawings very hard to read.
get the operators guide for car (lost it huh>?
see see chapter, FUSES
BINGO.
Jun 25, 2014 | 2001 Mercedes-Benz S-Class
Tip
DirecTV Remote Control Manual Download
Download DirecTV Universal Remote Control Manual
Have you lost your Owner's Manual for your DirecTV Universal Remote Control?
Would you like a digital copy of the DirecTV Universal Remote Control Users Guide for easy searching of terms and quick reference?
The DirecTV Universal Remote Control manual is available free in pdf format, just follow the link below (& Click FREE):
I hope that helps.
________________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Code Search
DirecTV Remote Control Code Entry
on Jun 10, 2010 | Televison & Video
Tip
I hope that helps.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
My phones died so I charged it and when I try to turn it on it says m blur n the word blur flashes as usual but its been on that same screen for likr ten minutes what do I do?
Hi, well hopefully it will NOT be anything too serious. Now first remove the battery, wait a minute, and replace the battery. Now see if it "Boots up" OK, if NOT, then even though you recharged maybe the battery had a fault, you must in this case obtain a new freshly charged battery, and try that one
try a hard Reset, see below... This will erase all data BUT it may get your phone back.
http://cellphonerepairtutorials.blogspot.com/2010/05/motorola-cliq-xt-mb501-hard-reset.html
http://cellphonerepairtutorials.blogspot.com/2010/05/motorola-cliq-xt-mb501-hard-reset.html .
Aug 25, 2010 | Motorola Mobility CLIQ Cell Phone
Hello I can hardly hear on all of my channels. I have directv and I can't get a reasonable volume. Is there something I can do to fix this problem?
Directv low volume problem.
One sure way to eliminate Directv's low volume and any other volume problems in general is by installing a stereo compressor between your Directv receivers audio outputs and your TV's audio inputs. (Simply plug the compressor's outputs into TV and your receiver outputs into the compressor's inputs). By correctly setting the controls on the compressor, you won't loose the dynamic program content. Not only will it raise the volume level to where you want it be, it will also prevent it from exceeding any set level you chose, actually limiting how loud any sound can be. These settings are fully adjustable. In other words when you switch from Directv back to a dvd or any source, no more sound blasting, you can set levels to be the same now since you have raised then adjusted Directv's level to normal. Plus a compressor will raise those low hard to hear audio sections often found in movies. This is the reason we used them all the time in the recording industry. Another benefit is it levels all channels on Directv. The result, channels are now the same volume. This is what I'm doing to end the problem. Hope this helps someone. J Pynckel
Jul 27, 2010 | Directv H21 DTV Receiver
We just bought a 55LH90 LG LED tv. Our directv
I used my directv remote to access the setup and was guided through the steps to make my directv remote the "do everything" remote.
Nov 02, 2009 | LG 55LH90 55 in. LCD HDTV
Certain aspect of my sanyo tv are very blurred
This problem requires adjusting the Focus on the flyback . Turn the tv around and look for adjustmen slots on the back. If you can see them, use a nonmetalic small srewdriver and slighty adjust the top or left one. Be careful, it is the high voltage area
Sep 15, 2009 | Sanyo Televison & Video
My RCA TV guide words is blurred but the
There are 2 things you try. go into menu to picture setup scroll down to sharpness,back this setting all the off. If this doesn't do it, go to back of the set on right hand side, if you can see focus slot adjust it slightly.
Sep 06, 2009 | RCA F25654BC 25" TV
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Sep 16, 2008 | Samsung DynaFlat TX-P3064W 30" TV
How to fix my 54" Magnavox rear projection tv
ACS module is bad hard to find vertually impossible, throw away your tv buy a new one.
Sep 30, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
176 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
