Question about Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5" Internal SATA II Hard Drive
Toshiba MK3265GSX 320GB Internal Hard Drive is clicking
Hard drive failure
  • 17 Answers
SOURCE: get the message 'hard drive failure imminent
Have you tried turning off/on again your laptop?
If you did but still getting the same message am afraid you will have to replace the hard disk
Posted on Jan 04, 2010
lock123
  • 6831 Answers
SOURCE: Toshiba 320gb external drive is not detected by any laptop...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
shibuda
  • 1812 Answers
SOURCE: How can I install internal
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Posted on Feb 27, 2011
  • 24 Answers
SOURCE: My portable Toshiba 320gb Hard
Unfortunately, this usually means you have some type of hardware problem. If you hear the drive spin up and just never connect to the computer, you are in better shape than most. The usual tricks to get around this are as follows:
  • Plug it into a different USB port, preferably on in a different part of the computer. The motherboard's USB hub might have flaked out.
  • Unplug it from the computer over night and try again later on. You may have tripped a thermal fuse on the USB line and sometimes they take a bit to reset.
  • If that fails, then remove the disk from the enclosure and hook it up to a machine with a free port. If you don't have one, I use Aprocorn DriveWire 3-in-one Disk interface to get on loose hard disks.
Unfortunately, there's really not much that can be done other than this. Good luck.
Posted on Feb 28, 2011
SOURCE: My portable Toshiba 320gb Hard Drive hddr320e04x
i have toshiba hddr320e04x but my computer cannot detect my device. what should i do?
Posted on Mar 04, 2011
Toshiba hdd
As far as I know it is not possible to remove a password from a hard disk. In some cases a manufacturer may be able to help, however, for security reasons I'm not sure they would.
Mar 18, 2014 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I need this controller board for MK3265GSX
Almost any SATA board will do so long as you have a free slot.
I notice you state its for a small form drive so my question it...
Are you talking about a laptop or regular PC ?
Half a question without detail gets you half an answer
Dec 10, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
Nov 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My laptop do not detect my hard(mk3265GSX) laptop is Dell inspiron 1600
Ensure that the hard disk is a working one and properly fix into your DELL laptop.
Best regards.
Jul 18, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
MY TOSHIBA HARD DISK MK3265GSX 320GB CANNOT DETECT TTO MY PC
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 13, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Hi my toshiba mk3265gsx hard disk is detect as a usb device as external, but not work and has no partition no bad disk and can not be able to work with this, it is just a usb device with no action (this...
With a brand new drive, you have to initiate your drive using the Disk Management tool in Windows.
To do this, go to Start-->Control Panel --> Administrative Tools --> Computer Management. Then select Disk Management from the menu on the left. Once everything is loaded up, you should see your new drive in the list of volumes on your computer. You'll have to right click on it and click Initialize Disk. Once you've initialized it, you'll have to formate the drive and create partitions.
If you need anymore help, let me know.
Mar 25, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
How can I install internal Toshiba MK3265GSX into my notebook with Windows XP (SP3)? Setup software can't find hard disk. Where can I find driver for this device for XP?
Hi
Feb 27, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My laptop does not see the hdd
Check your CMos setup and see if the hard drive is recognised there.
Feb 03, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5" Internal SATA II Hard Drive Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
