Question about Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range
Electrolux oven will not heat
After cleaning the oven with the self-clearning feature, the oven will not heat.
  • Official Brand Answer
  • 4,342 Answers
Hello Michael Anderson - From what you have described it sounds like the unit has faulty elements or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the unit.
Posted on Jan 06, 2013
  • Michael Anderson Jan 07, 2013
    Chris, thanks for your input the problem was a thermostat. There is a thermostat with a reset button on the back of the stove. It was that simple. However, I am a little peeved with Electrolux because I called them to ask if there were any reported problems with a thermostat aftert the self cleaning function was finished. They told me no. They lied to me because Electrolux has issued a fix to the problem that the Sears repairman referenced!
  • eric7570 Aug 03, 2013
    Worked for me today; same problem, same solution. Thanks, Michael.
3 Suggested Answers
ndguy2481
  • 251 Answers
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
Posted on Dec 01, 2008
  • 731 Answers
SOURCE: Hi! We have an Electrolux E36DF76EPS. I ran the
I'd check the thermostat for continuity first
Item 119 on this diagram
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Range-Parts/Model-E36DF76EPS/1412/0122007/R0705157/00003?blt=06&prst=0&shdMod=E36DF76EPS
Posted on Feb 08, 2011
I used the self clean feature & now oven does not heat
Hello friend, thank you for your post!
From my understanding your used the self-clean feature on your Electrolux oven and now it is not heating. This could be an issue with your control panel or thermostat. You may need to perform a reset on your range and you can do that by disconnecting power from it for at least ten minutes. If that does not help to alleviate your current issue with the range I would suggest seeking assistance from a professional technician for repairs. I hope this information is helpful to you. -Matt
Dec 30, 2015 | Electrolux Kitchen Ranges
Tip
Electrolux Model EI30GF55GSE Self Cleaning Doesn't Work
When using the self cleaning feature, you may see the panel flash remove shelves then go off after a minute. The solution is that there is a bar in the back left of the oven that is connected to the self cleaning sensor. After sitting a few months it may get stuck. Try moving or flipping the bar back and forth a few times. you should hear the sensor clicking . Then try to clean the oven. It worked for me.
on Oct 16, 2011 | Electrolux 30" Self-Cleaning Freestanding...
How to get it to do self clean and how long is it suppose to take
Electrolux Self-Cleaning Oven ' Electrolux Kitchen Range ...
? 0:47
https://www.youtube.com/watch?v=JNVPSVe_MV0
Mar 25, 2015 - Uploaded by Universal Appliance and Kitchen Center
Electrolux fresh clean feature is the perfect ingredient for cleaneroven, with 3 different levels of cleaning .
Manually Starting Self Clean cycle on Electrolux Washer
ths.gardenweb.com > Home Forums > Laundry Room
Feb 10, 2011 - So, I want to do a self clean cycle manually. ... wake up washer by pressing any button rotate cycle knob to handwash press start and then cancel. ... I am not sure my machine is operating on the clean cycle.
Nov 23, 2015 | Electrolux Vacuums
When I program for a self clean cycle the door lock icon doesn't come up. I can start the cycle but it doesn't heat up, just counts down the time.
Good Morning Gerry, thank you for your inquiry!
I see that your Electrolux oven door will not lock when you attempt to program your self-clean feature. This could be an issue with your door latch or control panel. In order to accurately locate the part needed for the repair of your oven you need to disassemble your oven and test each component. This is not a simple DIY job and I would suggest contacting a technician for proper repairs. They will have the appropriate tools needed for repair. I hope this information is helpful to you. -Matt
Mar 22, 2015 | Electrolux Ovens
I cleaned my oven with the self cleaning and now it will not heat up. What can I do?
If you have a problem with your Electrolux EW27EW55GS cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Feb 21, 2015 | Electrolux EW27EW55GS 27-in Electric...
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Electrolux wall oven not heating after self cleaning -- fan is going -- but it is not heating
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 17, 2010 | Ovens
After I ran the self cleaning function on my
Sounds like you have burned out the element. The self cleaning cycle takes the oven to a temperature that is well beyond 500'F. It stresses the element to a point where it gets faaarr tooo hot!
Dec 14, 2009 | Electrolux Kitchen Ranges
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range Logo
135 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
