Question about Maytag Bravos MTW6600T Top Load Washer
What does code f 51 mean
Starts then turns off
    Sergeant:
  • 291 Answers
Here are available manuals:
https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212
You will want to look at "owners manual" and "parts list." Not sure why each category has four PDF versions available. Although the owner's manual does not address the specific code F 51 it does say this in the troubleshooting section:
F_ _ "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
Posted on Jan 01, 2013
Code 34 and 51
Code 34 is for the MAP sensor voltage being low which means the sensor is unplugged or faulty. Code 51 is for a problem with the memory chip inside the computer.
If the engine computer is failing it could set the code 34 even if nothing is wrong with the MAP sensor.
The computer and MAP sensor would need to be checked out.
Jul 15, 2013 | Chevrolet Cars & Trucks
Tv want turn on and has code 4
I think error 4 means a problem with the logic board, usually an ic blown.
Jun 07, 2008 | Sony KP-51HW40 51" Rear Projection...
What is that mean code f 51 on my wash machine
1) motor RPS failure, this mean SENSOR faulty between the motor vs board.
2) clean the sensor from oxide, dirty, and tight the wires connector very well.
3) This is a difficult process for to access him. If you do not have enough experience, you must call a service tech.
God bless you
Jun 29, 2012 | Maytag Washing Machines
Washer does not work it goes into error code f51
F 51 error code means the computer cannot detect that the motor is turning properly. The most common cause of this problem is an article of clothing has gotten between the basket and tub and is stopping the basket from turning freely. There are several other possibilities but I have seen this cause an F 51 error code many times. Hope that helps.
Aug 29, 2011 | Maytag Washing Machines
What do the engine codes 12, 51, and 17 mean on a 1995 Jeep Cherokee 4 cylinder , 2 whd, 5 speed. It has a rough idle, really low fuel mileage, and not much power. Just recently started this problem.... I...
Code 12; Means the PCM sensed the battery was disconnected and after 50 key cycles, this code will disappear. Code 17; Means the engine is cold too long after start up. Engine coolant temp remains below normal operating range during vehicle travel. The thermostat is stuck open; replace the thermostat. Code 51; The O2 sensor stays below center voltage outout. And indicates a rich fuel condition. This is caused by the stuck open thermostat.
Oct 22, 2010 | 1995 Jeep Cherokee
1994 F150 Airbag Trouble Code 51
Code 51 means you have to retrieve the real code from the computer.
Ignition switch should be on with engine off.
Locate the black RABS II diagnostic connector.
Disconnect the two halves.
Attach a jumper wire to the black with orange stripe wire side of the diagnostic connector. Ground the jumper wire ground for a few seconds. ABS lamp should start flashing.
Count the flashes. For example, three short flashes followed by one long flash indicates diagnostic trouble Code 4. The code will continue to repeat itself until the key is turned off. A code of 16 means normal system operation.
The last step of the system test always includes clearing the Keep Alive Memory (KAM).
To do this, simply turn off the ignition while the diagnostic connector halves are separated
Then diagnostic connector should be re-assembled.
After getting the real code, then we can look it up and see what the 51 was trying to tell us to look for.
Sep 05, 2010 | 1994 Ford F150 Styleside Supercab
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Service code 51,52,53,54,55,99
The Sony will turn off or won't startup !!
Code : 51 ... 52 ... 53 ... 54 ... 55 indicate to the group of fans on the back side.
When recieving all numbers 51 til 55 means that NONE ofn the fans are functional.
result of this four codes will be that Code 99 show up , and turn off your sony.
Findout what corses the problem with the fans and code 99 will removed allso.
Best regards , EuroNet 2000 The Netherlands
info@euronet-2000.nl
Jun 06, 2009 | Sony PFM-500A2W 42 in. Television
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Maytag Bravos MTW6600T Top Load Washer Logo
123 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
