Question about Makita MAC2400 Electric Powered Air Compressors
Dont know what kind of oil to put in my makita mac2400r compresso
Compressor oil? mac2400r
    President:
  • Makita Master
  • 1,388 Answers
If your compressor is used all day purchase synthetic blend compressor oil sold at lowes and other stores. It will increase the life of your machine. Sells for about $7. for 16oz. For normal use use standard air compressor oil sold at lowes, home depot and even at wal mart. Wal mart's Super Tech Air Compressor oil sells for less than $3. and works well. Do not use motor oil with detergent as this type of oil causes carbon deposits to build-up in the head and discharge hose which will eventually clog the check valve and lower efficiency. If you remove the plastic sight glass, use caution, because this part easily cracks. Purchase a spare sight glass and keep in your tool box. Good luck
Posted on Jan 19, 2009
Hr2621 makita what kind of oil do I put in it
Use a wheel bearing grease. Oil is too light.
Nov 27, 2016 | Makita Garden
What kind of oil do use for it.
There is special oil available for compressors. It should be available at all better hardware outlets. On small domestic type compressors with aluminuim cylinders it is not advisable to use automotive oil.
May 27, 2011 | Makita MAC700 2 HP Air Compressor (Hot...
Mac 5200--what type of oil and how much oil does it take?
Use air compressor oil only, motor oils like 10W-30 will leave carbon deposits on components and reduce their performance and compressor life. No manual lists an exact amount of oil to put in, they just say fill until the oil is half way up the sight glass. It's usually +/- one cup depending on the model, some take as much as one pint. Go by the sight glass for the best performance and to protect your compressor.
Feb 17, 2011 | Makita MAC5200 Electric Powered Air...
My makita keeps sticking and not firing out the nails getting frustrated with it
check the air pressure from the compressor -- I am sure that you need 80 -100lbs of pressure in order to shoot and complete a cycle. also drop a few drops of oil ( tool oil ) into the air intake hole and also put some oil along the firing pin slide,, also check to see if the load spring is strong and not broken or disconnected.
c...
Dec 29, 2010 | Makita Garden
Makita mac5200 compressor doesnt like the cold would like to swap oil for synthetic what should i use for winter
hi buddy compressor oil is oil there is no synthetic its one type really i will run on any compressor oil its not an engine you can buy oil on ebay buddy
Oct 14, 2009 | Makita MAC5200 Electric Powered Air...
Brand new Makita MAC2400 is leaking oil.
Send it back Right now do not keep iT NO IT SHOULD NOT BE LEAKING LIKE THAT Paul
Jul 03, 2009 | Makita MAC2400 Electric Powered Air...
Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Feb 26, 2009 | Makita Brad Nailer Finish Nailer...
Makita MAC 5200 3 HP 5.2 Gallon electric compressor
Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
Feb 22, 2009 | Makita MAC5200 Electric Powered Air...
Makita MAC2400 Electric Powered Air Compressors Logo
636 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
