My computer will no longer recognize the memory
I tried to upgrade my MB from 12gb of ram to 14gb ram with 2 new moduels that were bad (I tested them in another computer and they wouldn't work) With the bad ram installed, on boot-up I get 3 short beeps telling me I have a memory problem. So i reinstalled the original working modules and now I still get the 3 beeps no matter how I configure the installation I always get 3 beeps. I removed the battery with now power supplied to the MB and also reset cmos and it doesn't make a difference. Could the bad ram effect my bios or possiblly the chipset on my MB.
  • 4,806 Answers
Hi.
Try this >>>>
Remove the power cable and lay the computer on its side. Remove all the RAM from the unit ad make sure all the brass contacts are clean. After that take a look at the slots and make sure they are free of any dust.
Plug in the power cable and start putting the RAM back in one at a time turning the machine on with each module to try, that will determine which of the modules maybe faulty, it just maybe a case that you haven't put them in properly.
Good luck and regards.
Posted on Jan 01, 2013
  • Michael Richards Jan 03, 2013
    Yes I have already done what you have suggested I guess I will just have to buy another MB.
djnick989
  • 1067 Answers
SOURCE: installing new memory
ya cuse old moduel is slower hu drops speed back to 2700 and not 3200 ? corect its in bios settings re auto detect ram set to automatic config itself what brand ram u buy sum fox commm bords very picky on low denstiy and hi density styles ok low beter more compatble 38 bucks 1 gb on ebay ddr 400 i run 3 of those in my gigybyte moby and it loweres my ram spee dto 333mhz not 400 when i use all the slots up cheak your bios settings let me know name brand usally the pp who make it call them tell thenm and ask for time settings to be best with your mobo ok if they have great tech support if not tell me models
Posted on Jan 17, 2008
djnick989
  • 1067 Answers
SOURCE: Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Posted on Jan 21, 2008
suisboy
  • 175 Answers
SOURCE: p4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Posted on Nov 08, 2008
  • 42 Answers
SOURCE: Will not run 3 gigs of RAM on the MB
its falt of internal battery
Posted on Apr 06, 2009
  • 165 Answers
SOURCE: no boot
Check to make sure you don't have any extra standoffs under the motherboard that may be shorting it out.
Posted on Jun 20, 2009
I have a Toshiba Satellite A10-S129. It was working with 256 MB (2 x 128 MB). I wanted to upgrade it to 512 MB (2 x 256 MB). I bought 2 new 256 Modules and when changed it and turned on screen has...
If you get several beeps then there is a video problem. The video card uses shared RAM (part of the main RAM) and if the RAM is faulty the laptop won't boot up.
You might have incompatible RAM, try to use the same make and speed RAM as the original.
One of the RAM modules may be faulty.
Try installing one 256Mb RAM module then boot up the Toshiba, if it works the try the other RAM module.
Mar 20, 2011 | Toshiba Satellite A10-S129 Notebook
INSTALLED NEW RAM UPGRADE TO BOOST FROM 1G TO 2G COMPUTER DOES NOT RECOGNIZE NEW RAM STILL SHOWS 1G.
Make sure it is the correct ram for your computer. If you just added one ram chip then try swapping them and make sure they have a tight fit.
To test the new chip replace the old one with it and turn on your machine. If it doesn't see it then it is either bad or not the correct one.
Let me know how it goes.
Dec 14, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
After ive installed assassin creed it comes up u need bla bla bla so then it says renewing up dates and is now 100% fixed its in folder and on icon yet when i try to plsy it comes on in about 2 flashes and...
Here are the requirements for the game. What graphics card are you trying to use? If your PC doesn't meet the specs, you may have to consider upgrading the RAM and graphics card.
MINIMUM REQUIREMENTS
Assassin's Creed
Processor: Dual core processor 2.6 GHz Intel Pentium D or AMD Athlon 64 X2 3800+
RAM: 2 GB
Video Card: 256 MB DirectX 10.0-compliant video card or DirectX 9.0-compliant card with Shader Model 3.0 or higher
Sound Card: DirectX 9.0 or 10.0 compliant sound card
HDD Space: 12GB
DirectX Version: DirectX 10.0
RECOMMENDED REQUIREMENTS
Assassin's Creed
Processor: Intel Core 2 Duo 2.2 GHz or AMD Athlon 64 X2 4400+ or better
RAM: 3GB
Video Card: 512 MB Card
Sound Card: 5.1 Sound Card
HDD Space: 12GB
Jul 11, 2009 | Computers & Internet
Gateway M505 memory upgrade not recognized
two things it could be either it don't support that much ram are 1 ban stick of ram
Mar 30, 2009 | Gateway M505 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Sep 18, 2008 | Gateway 835GM (835GH) PC Desktop
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
David Payne
David Payne
