Question about Linksys Wireless-G WRT54G Router
I Can't get my new router to work
I used to have and old router. It worked perfectly. I had it all worked out. But then my buddy gave me this web sight and I got a bug. Then when I cleaned out my computer I found out that the router died. So I got a new one. But I can't get it to work. Oh yeah I have this Verizon Modem thing and now I can't get it to work. I need help. I need help because when I try to use it the router says its conneted to the Internet. But When the Router disk does the scan It says that the router can't connect to the Internet. I have no idea why. When I check the router the Internet light is still on. I really need help.
    Problem Solver:
  • 14 Answers
Host Name and Domain Name are not required fields by Verizon Online. LAN IP Address is by default: 192.168.1.1 Subnet Mask should be 255.255.255.0 Wireless should be Enabled to use wireless capabilities. The ESSID is by default: linksys. (It can be changed, but ALL devices that communicate using the wireless network must have the same ESSID) Channel is by default 6 and WEP is by default set to Disable. WAN Connection Type is how the router gets it's IP address from the network. Obtain an IP automatically is the DHCP setting. PPPoE settings: User Name and Password: as supplied by Verizon Online. If Connect on Demand is selected, the router will only connect when needed. Keep alive should be selected and is the recommended setting for Verizon Online. Note: Click the Drop-Down to access other Connections types. (DHCP and Static). Click Password to continue
Posted on Jul 22, 2007
I work for verizon dsl as advanced tech support. it could be that your modem and router have the same ip go into the router and change the ip to 192.168.2.1 and power cycle, that should get you online
Posted on Jun 27, 2007
  • 196 Answers
The easiest way to solve this might be to reset the router to its defaults and start over. Most routers have a reset button on the back. Check your manual for this procedure. Once you've done that, insert the install disk and follow the directions carefully. This is a fairly bullet-proof routine nowadays. If you need more help, let me know your Router make and model and your computer OS.
Posted on Jun 25, 2007
SOURCE:
Hulu and Netflix etc will not stop buffereing every minute or two....
Note that "buffering" occurs when the "stream" (audio and/or video) is not being received as fast as it is being consumed.
Find a "network speed test" web-site, to see if your Internet connection is working properly. Try different Ethernet cables, to ensure that a bad cable is not causing any problems. If you have other computers on your in-house network, turn them off, to see if they have been "heavy" users of your Internet connection.
Mar 06, 2015 | Apple Computers & Internet
How do I reconfigure a used router?
You sure can. You just need to resent the router to default settings including username/password, and reconfigure it all over.
Further instruction can be provided if you tell us the model of the router, and the type of Internet Service.
Jan 09, 2013 | Belkin Computers & Internet
MX700 mouse Working this morning then quit this afternoon. I put new batteries in it.(mouse is about 5 month old) Updated the drive for it still nothing the cursor just sit in the center of screen. I...
The new router could very well be causing wireless interference. Try moving the router away or turning it off and see if the mouse works. If it does, try changing the channel number on the router to see if that is causing the problem as it's possible both the mouse and router are using the same wireless channel and clashing. You can usually find the channel option in the Wireless Settings page of your router setup web interface.
Mar 23, 2011 | Computers & Internet
I need to setup my d link router but ip address wont work on my web browser?
you may need to use internet explorer firefox wont work for me Open http://192.168.0.1/ in your web browser ie internet explorer and btw buddy this is not your ip adress it is your settings ip that will help get your question asnwered quicker in future
Feb 17, 2011 | D-Link DIR-600 Router
Had a router in my home in another state, gave mom the router, which lives in another state. Can get wireless now , but cannot secure the network for her.
The web-server inside most routers deliberately is *NOT* accessible from the Internet.
The easiest way "out" would be to buy a new router, totally configure it, and then ship it to her,
and then talk her through disconnecting the old router, and connecting the new router.
Nov 28, 2010 | Computers & Internet
Will not connect to the internet
Your router may need to have the firmware updated, or it needs to be reset or unplugged for 10 seconds to reset it.
You can set up a home network and make sure all settings are set to automatic
Aug 25, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
How do I connect a MaxG wireless router into a SmartAX MT880 DSL modem
  • Connect cable from router to computer ...
  • Connect cable from router (internet port) to the modem ....
  • U will be able to go online ....
  • And after it is done ...u can do the wireless settings ....
  • then connect to network and u will be perfectly able to go online ....
Oct 24, 2008 | U.S. Robotics (USR8054) Router
2wire 1800HG Router with no software
You can manually configure it , so I may suggest you to call the manufacturer of the router or your ISP and they can walk you through in manually configuring this router.
Hope that helps........
Aug 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Linksys Wireless-G WRT54G Router Logo
104 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
