Unable to power on tv it kept staying on standby mode
Try unpluging the unit and then plug back in.
Posted on Jan 01, 2013
freetek
  • 5568 Answers
SOURCE: TV & Tuner stays in Standby mode
Assuming you have tried changing batteries in your remote and any front panel power switch your set has, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.  What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 29, 2008
  • 108 Answers
SOURCE: tv keeps knocking off to standby mode
It is most likely going to be a defective power supply but there are some other circuits that can cause the problem. I would start by unloading the power supply.
Posted on Jan 08, 2009
  • 4234 Answers
SOURCE: STANDBY MODE FOR PANASONIC FLATSCREEN TV TH-42HD6
Your TV is in protect mode. A problem was detected and the set shutdown. Is there a pattern to the blinking?
Dan
Posted on Mar 21, 2009
SOURCE: MY ILO LCT27HA36 TV won't come on, it just stays in standby mode/
I had the same problem. Then it worked for a while with me unplugging it and plugging it back in. Then one day it bit the dust. Nothing but the red light.
I found the solution on this website and I am trying to find it to thank the guy who posted it. For less than 10 bucks at Radio Shack, I was able to fix the problem with his instructions. And I know little to nothing about electronics. What it boils down to is this:
1. Lay the TV face down on something soft.
2. Take out the gazillion screws in the back until the back panel(s) come off.
3. Where the power cord plugs in, there is a ground wire going to a screw and another plug that you can undo. On this circuit board lies the problem.
4. Remove the circuit board (there are several other plugs on it. They all fit only one way, so I didn't pay much attention to how they came off.
5. Look on the board at the light blue cylindrical shaped capacitors. I don't remember how many there are, but look at the top of them. Find any that are bulging slightly at the top. They should be easy to spot. I had six on mine that were bulging. If you are handy with a soldering iron, remove the bad ones, making sure where each one comes from. There are a couple of different types/sizes. It is written on the side of each the resistance and what I assume is the voltage.
6. Go to the local Radio Shack and purchase new resistors. Note: I had some that were 1000 um and 36v or something and some that were 440 um and 16v. I couldn't find an exact match on one of those, but according to who I got my instructions from, as long as the resistance (um) number is the same, you can go up in the volts. So I ended up replacing some that were 16v with like 35v but the resistance (um) was the same and there are no problems.
7. Solder them carefully back into place. The circuit board is clear about which hole is positive (+) so don't get them backwards. The ones I bought from Radio Shack had a stripe on the side that was negative.
8. Put it all back together, and there ya have it.
Cheap fix. I admit I was darn skeptical it would work. I had already bought a new tv, but decided I wouldn't be out much if it didn't work. But it is working like the day I bought it again. And, it has a better picture than the Philips LCD tv that I bought to replace it.
Wish I could find the guy I got that info from. I was very impressed and grateful.
Hope this works for someone.
Posted on May 26, 2009
SOURCE: standby red diode stays
this is a problem with the switch mode power supply unit,check for the components not functioning in this unit and replace
Posted on Sep 22, 2011
Is it normal for an acoustic solution 24" LCD TV to stay for like 10seconds before coming up after switching on from the stand by mode?
10 seconds doesn't seem an excessive amount of time. Standby is supposed to be a power saving mode - the fewer parts of the circuit that are kept in complete readiness for switch on, the less power will be saved.
These days there is much prejudice against using the standby mode and it would be expected designers would respond to this by changing the internal arrangements so standby consumes less power so when the set is switched on it will take time for capacitors to charge and digital computers to fully boot and so forth.
Think of it not so much as a TV but as a computer. A 10 second reboot from the sleep mode wouldn't be so unusual...
If the TV works ok otherwise you probably have no worries...
Sep 06, 2017 | Televison & Video
Will not store settings unless kept in standby. Contrast/Brightness/Colour/Volume
1. The on/off switch is not easily accessible because the remote control is used to turn the TV on and off.
2. If the remote is used, the TV is always in standby mode
3. When the power is turned off and then back on those settings go back to their preset values or the last preset settings.
4, You should be able to enter the preset settings with the original remote control,
Sep 17, 2017 | Watches
My hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Feb 28, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Tv keeps knocking off to standby mode
Jan 07, 2009 | Televison & Video
Will not come out of standby
The reported problem is either:
A) your input signal is not being received (or is too weak), so the TV remains in standby mode...check the antenna or SAT or cable connection AND be sure the selection on the remote matches the intended input
OR
B) the TV Guide feature is unable to connect to the update correctly....power down the set (unplug if necessary) for 10- 15 minutes, power on and enter 0-0-0-0-0 as the zip code for the TV Guide...
Nov 05, 2008 | Pioneer PDP-505CMX 50 in. Plasma...
Goldstar TV (unknown model)
tv has a power supply fault requires service
Oct 22, 2008 | JVC AV-27530 27" TV
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
TV Switches itself back to standby mode continuously
if your remote is ok then this is due to power supply failure in your tv. either it is loose in oscillator ckt in switching section or it has failed. if not tech person call tech to fix it. not a major problem.
Oct 07, 2007 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
