Question about Vacuums
How to clean out the bag compartment above the filter cup
Fabric bag above filter cup needs cleaned. Is there a way to remove the fabric bag?
  • Vacuums Master
  • 18,394 Answers
What make is it ?
Posted on Jan 01, 2013
SOURCE: My vacuum is not sucking at all.....
I took out the air flow filter at the back of the vacuum and turned it on, somehow the clog cleared. Then I put the filter back in and it works perfectly! Barb
Posted on Jun 13, 2007
reddevil6
  • 1673 Answers
SOURCE: VACUUM CLEANER REPAIR
If the motor is real loud, then it is bad and will have to be replaced. Either the fan or motor bearings have gone bad.
Posted on Feb 05, 2008
SOURCE: Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
Posted on May 21, 2009
  • 5 Answers
SOURCE: I need to clean the main filter
Be sure you wash the filter that is above the canister compartment. It has an orange lever to release it. I over looked this the first year I had the vaccume, dust was really caked in there. I also just wash out the inside of the canister with water once in awhile.
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: remove plastic shield and access to dirt cup orange filter
I used a table knife in the very front of the brush area, there is an angled chanel. the inner piece of plastic with the roller assy just fellout once all of the screws were removed. I also just wash out the orange funnel piece after vaccuming every 2 months or so.
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My dirt deivl want pick up dirt that well. what is the promblem?
Most likely, it needs to be cleaned out. Change the bag (or clean the dirty cup), change or clean all filters and hoses . Clean the brushes. It probably sucked up some water and combined with dirt it clogs up filters and hoses.
Oct 18, 2011 | Vacuums
My Riccar Upright leave lines of debris when I use it. Can you help?
Inspect the filter.Open the secondary filter on the base of the vacuum to ensure that dirt and debris have not collected on the filter, as this will limit motor performance. Remove the filter from the dust compartment and rinse with water to clean. Allow it to dry completely and return to the dust compartment.--------
Also check if dust bag is got over full and that is causing the problem.Open the dust compartment, take the old dust bag out of the bag holder and discard. Open the end of a new dust bag and attach to the dust bag holder. Close the dust compartment and tighten the dust cover.Also check properly that dust compartment is not got loose. Open cleaning attachment and check the hoses and nozzles on the frequently to ensure that they are free of dirt, obstruction or hair.Also inspect the brushes, if there is already dirt got stuck in the brushes and that is causing the problem.Clean the brushed.---------- This will help, to confirm where the problem is and to resolve the dirt /debris issue.----- Thanks.Helpmech.
Sep 06, 2011 | Vacuums
My hoover Windtunnle model U5781-900.turns off while in use. After sitting for about 30 min it will work again for about 10 min and then shut off agian.
This is a result of the motor overheating. Try cleaning the filter above the dirt cup. Remove the dirt cup and right above should be a grey plastic cover. Slide the lock to get to the filter. Once you clean the filter, allow it dry and place everything back the way it was. This should allow the vacuum to work much longer.
Jan 15, 2011 | Vacuums
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
How to remove the eureka the boss super lite filter
Push up on the black slide button just above the dump cup and hold. With your other hand remove the dump cup. Once you have the dump cup removed, pull up on the rubber section of the filter to remove and clean the filter.
Feb 13, 2010 | Eureka Boss Superbroom Bagless VacuumStick...
My canister machine kicks off immediately after starting and bag full light goes on but it has a new bag
hi from uk your problem with vac may be the gauze filter on the inside of the compartment that has bag this filter there to allow air from the micro pores of the bag to expel to the exterior of vac (room) whilst preventing dust from expelling too ? normally another symptom of this is the vac cover sometimes flips up ? however if air cannot expel from compartment it will cause overheat of motor resulting in auto cut off but will reset when cooled SO check the filter gauze and renew or wash clean? hope you understand above and hope this helps ?
Oct 09, 2009 | Electrolux Guardian Bagged Canister Vacuum
I need to know how to remove the dirt container on the eureka bagless vacuum. It says that it is easy to remove, yet we cant figure it out. is there some trick to it that we dont know?
there is a lever at the bottom of the dirt cup,turn it to the left and pull out the dirt cup.note while you have the dirt cup out make sure you clean all the filters there is one right above the dirt cup pull out on the right side and there is a filter on it and at the bottom right below the dirt cup there is a door that says hepa.clean that one to.then your good to go
Apr 23, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Mar 18, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My self-propelled windtunnel bagless hoover does not pick up.
Remove the dirt cup.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
Feb 21, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
