Question about GE Dishwashers
I need to replace my dishwasher. I need to know size specs to order one that will fit. My measurements are a little dif. Then what is offered. Can anyone help??? Ge model no. Gsd4030y70ww
Need size specs please
SOURCE: How do I remove the top rack on the ge profile built-in dishwashe
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
Posted on Nov 30, 2008
SOURCE: size specs
The measurements are difficult to find and verify. However, you can call Kitchen Aid. They will be able to mail or fax you a copy of the original user manual which should have the specs. The number is: 800-422-1230
Posted on Jan 08, 2009
whytfang
  • 170 Answers
SOURCE: I have a ge nautilus built in dishwasher and do
You can find them on a label on the tub wall just inside the door. However 99% of all DW are a standard size and the difference is made up by adjustments of the threaded leveling /adjustment legs.
Standard size is 24" x 32-36"...you can take a tape measure and measure from the floor to the bottom of the countertop it is to be installed under...and then measure across the front of the DW. you should find my measurements to be within this range unless it is a custom unit.
Hope this helps. ...good luck and good day...The Fang
Posted on Mar 28, 2009
Maytag317
  • 1136 Answers
SOURCE: I want to replace my dishwasher but dont know what size would fit
Hi, There are two sizes. 30" or 24".
Just measurethe dor or cabinet and you will know. I hope this helps you.
Vic
Posted on May 16, 2009
SOURCE: GE Potscrubber 720 attachment
i got mine from the local Home Depot. its called a "bubble stream Large Snap Fitting"
Posted on Jul 08, 2009
Need to replace a whirlpool quiet wash plus dishwasher. Which current model available can be used to replace it?
measure the gap you have to fix a dish washer in and see what model they have of the same size to fit your needs .
Feb 17, 2018 | Whirlpool Dishwashers
AIWA AD-F800 Replaced belts, old ones totally degraded. If I insert a cassette it will play but only play for 2 seconds (good audio out) but then it stops?
It is important to thoroughly degrease the pulleys before fitting the new belts and it also helps to remove some of the polished drive surfaces with some fine Scotchbrite.
It can also be the perfect time to apply a little light machine oil here and there with a precision oiler.
Finding new belts can be a problem. Most people left to their own initiative will select a belt that fits, often using the old belt as a pattern or by measuring. Unfortunately it is rare the correct size of belt will provide enough friction to drive everything successfully. As a general rule the square or round section belts of the right size must be stretched considerably in order to do the job. Even flat neoprene belts must be stretched by a large amount to fit and drive.
In the absence of knowing the correct size it is well to measure and guesstimate a suitable size smaller and then fit progressively smaller until satisfactory operation is achieved.
Apr 01, 2017 | Aiwa Audio Players & Recorders
WHAT THE CUBIC FOOT SIZE FOR THE MEASUREMENTS OF 62"H x 23.5"W x 24"D?
The cubic ft capacity spec on a fridge is measured inside, and varies depending on its design, especially on whether it has an ice maker, although those measurements you give seem to be for a bar fridge or similar.
Your measurements come to 20.3 cu ft on the outside, but remember that is not relevant, you have to measure the dimensions to make sure it fits.
Feb 25, 2016 | Refrigerators
I am replacing this and need to find the specs so I can get the right size dishwasher
Standard built in dishwashers basically only come in a couple of sizes, however, to answer your question, I would need to know what "this" is in your question.
Here is a link to some drawings of different dishwasher sizes
built in dishwasher sizes Google Search
Sep 25, 2015 | Dishwashers
Hi, I need to find out the dimenions of my dishwasher or the number of the one to replace it?
Mobile home stuff is usually smaller house stuff is usually bigger but they just run different sizes just take the measurements of your old one and then check the specs over the computer of the new one or possibly look on Craigslist for a free one the same kind and slip it in
Aug 07, 2014 | Baumatic 23 in. BDW10 Built-in Dishwasher
How do i know what size heli coil i need on my 4.6 e150 or how can i measure the size to know?
The best way is to measure a bolt of the same size and pitch as was fitted in that threaded hole. The specs are the same for both eg M10 x 1.5 or whatever. Then you can take this info, or better, the bolt itself, along and buy a helicoil kit to suit.
If it is for a spark plug hole, they will know immediately on seeing one of your spark plugs (there are 2 main sizes). It is probably also on the back of the kit packet.
The other way is to drill and tap out the hole for a larger size screw or bolt than you had to begin with. Generally you would use a tap drill for the next larger standard size thread.
May 30, 2012 | 1999 Ford F150 Regular Cab
I need to fit a new drain hose to my Bosch Dishwsher Model No. SGS546A72/42 . Is this easy to do and can I obtain a diagram to assist.
not all models use the same size drain hose. you need to know what size the out put of the unit (could be found in the user manual or measure the outside diameter of the outlet on the unit.) also you need to know what is the size of the connection to the drain on the pipe under the sink or where ever it is located. it is also best if you know the length that you will need don't go short a little extra can usually be better than to short. with all of the above written down on paper go to the hardware store (I like Lowes) and have the store person show you what he has for your dishwasher. I like to put clamps on the hoses as it keeps them inplace and will eliminate future leaks.
Jun 21, 2011 | Dishwashers
Vic
May 16, 2009 | Dishwashers
Size specs
Jan 08, 2009 | Dishwashers
Dishwashers Logo
54 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
