Audio is displayed on tv screen - Televison & Video
If you mean subtitles are being displayed after you have used the pause function, try pressing "OK" and then "OK" again and this should remove them.
Posted on Jan 05, 2013
What could be wrong with my TV? The audio and video suddenly cut out.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 15, 2016 | LG 42" 5400 Series LED HDTV - 42LN5400
Can a tv inverter board cause tv to not display
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Apr 17, 2015 | Coby 40 TFTV4028 LCD TV
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
There is something on some channels that is describing verbally what is happening on screen and we can't find out how to turn it off
Just look at the remote and find a button that is labeled MTS, SAP or Audio. Press this button one time and a display on your TV will show you the audio that your set is tuned to, (i.e., English or Spanish). If it shows AUDIO 2 or Spanish, press the button again until it displays AUDIO 1 or English then press ENTER or OK. With that, the audio should be correct.
Read more: http://www.kmbc.com/Descriptive-Audio-and-SAP-Audio-on-KMBC-TV-and-KCWE-TV/-/11664900/16438214/-/hay9otz/-/index.html#ixzz2eY64CP1f
Sep 09, 2013 | Televison & Video
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
Need directions on how to hook system up to tv
Check the back of the system, you will find Video out, then Audio out (left and right). Connect the yellow cord to video out, and the white & red to Audio out appropriately.
Then connect the other end of the yellow cord to "Video in" at the back of the TV, then the red and white to audio in at the back of the TV.
After connecting as directed above, turn on the TV, then turn on the system. On the TV remote control, press "AV" or "Source" depending on what is written on the remote and there should be a display. If there is no display, press the "AV" or "Source" on the remote once or twice more and there should be a display of the receiver's welcome screen on the TV. You might also need to press "Source" on the system's remote if there no display.
Let me know if you don't av display even after following the above steps. The above is the correct way of connecting so it should work.
Note; The White and Red cords stands for Audio left and right, while the yellow cord stands for Video. The yellow is suppose to allow your system display on the TV screen, while the Red and White is to bring out sound.
I hope the above helps.
Good luck.
Feb 01, 2011 | Audio Players & Recorders
No audio, no video but program guide displays
1. You should check you cabling connections at the satellite receiver to the TV.
2. Check the mode you are in on the HDMI cable
3. Your HDMI should have 3 modes in the set up screen (HDMI 1,2,3)
Apr 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
No Video but have Audio
I found my product manual and called the Tech Support line. They said it was a problem with the display and would have to schedule and appointment to fix it.
Jun 19, 2009 | Dynex DX-LCD32-09 LCD TV
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
