Question about AEG Lavamat 72640 Front Load Washer
How do I take the top off an AEG 72620- w
I need to replace the water distributor that sits above the wash powder dispenser. I beleive I need to take the lid off. Have unscrewed the retaining screws at the back so the back of the top is free but don't want to force the front. Please help.
  • gavin459 Jan 18, 2009
    Thankyou for the solution but the question, and the difficulty, related to getting the lid off the washing machine before even getting to the distributor. I have now managed to get the top off the washing machine with gentle prising and have replaced the distributor, so my original question is now defunct and no longer needing an answer.
    Sergeant:
    Champion:
  • 435 Answers
Hi, What is the make and model of this product ?
Posted on Jan 18, 2009
  • Karthik P Jan 18, 2009
    Look at the new water distributor unit.
    Now you would know, how it fits and the position of all screws.
    Unscrew them from the old unit and replace with the new one.
    Scholar:
  • 160 Answers
Just tuck up the lid from the sides to open up locks in the front side.
    Sergeant:
  • 378 Answers
Yes you r going right just you can continue.but after removing the screws just check out for rthe plastic locks that r holding the distributor.
Water leaking out of soap dispenser?
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
I have replaced the water distribution part on my aeg 72620 Lavamat as the original part was faulty. With the new part fitted and on a main wash the water is diverted to the pre wash compartment - is the...
If wates is diverted to the wrong compartment, it can be a faulty pcb, faulty control/timer switch, or valve not opening or obstructed duct.
Apr 11, 2008 | Washing Machines
Machine not taking powder
From your comment the water feed into the wash powder section of the dispenser tray is not working properly. Follow these instructions for first removing the dispenser and thoroughly cleaning and then clean all of the jets where the water is supposed to enter. Afterwards replace the dispenser;-0)
Try the following- in the second and third cases whilst looking from underneath!
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit).You may have to push the bottom of the dispenser upwards.
  • lift upwards on the tray as it is coming out to clear the lip underneath. Again you may have to push the bottom of the dispenser upwards.
Pull out the dispenser drawer far enough to be able to just see the trays, select each part of the cycle in turn (briefly to save time) and check that water is entering the trays. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 17, 2011 | AEG Lavamat 72640 Front Load Washer
Mijn AEG oko lavamat 72620 meld code 9
AEG code 9- tacho/motor fault ;-0(
Sorry,
John C
Mar 19, 2011 | AEG Washing Machines
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 72620 door does not open
It seems that your problem is with the lid switch and it should be replaced. The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. Good luck!
Sep 05, 2007 | AEG Lavamat 72640 Front Load Washer
Washing machine AEG 72620 not functioning.
Having worked for AEG for over ten years, the fault is a faulty dispenser unit ( top of soap draw) only fix is to replace the unit ( cost approx £45)
Aug 29, 2007 | AEG Lavamat 72640 Front Load Washer
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
55 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
