Replacement button mouse button
  • 7,627 Answers
Replace mouse.
Posted on Jan 01, 2013
  • smzeqiri
    smzeqiri Jan 03, 2013
    It's the left hand mouse button that's on the keypad that's broken. I've done a bit more research and it seems as though I need to purchase a kit with lots of bits in that comes in at around 46 quid. Or pick up an old bit of kit and use the buttons from that. Thanks though.
My mouse's left button is not working while other button is working
Most USB mice are plug and play, so driver install are automatic. This sounds more like a hardware malfunction. Try plugging the mouse in to a different computer, and if the issue persists, the mouse button is probably physically damaged and it's probably easier to just replace the mouse than trying to fix the broken button mechanism.
Apr 14, 2012 | HP Wireless Optical Mouse
HOw to replace the mouse left click and right click
The mouse click changes are based on OS used.
In windows OS ..Click Start button on your windows desktop. Select and click on Control Panel from the menu. Select and click Mouse from the control panel. From the Mouse Properties Window, select the Buttons tab. Select and check the Switch Primary and Secondary Buttons check box. Click the OK button.
Your mouse buttons should now be switched around, so now when you click your left mouse button, it will behave as a right-click, and clicking your right mouse button will behave as a left click.
Dec 01, 2010 | HP Compaq Presario C306US Notebook
How to replace the batteries of Cordless logitech mouse of my pc
If it is a LOGITECH V 220 it will be at the bottom of the mouse.
Regards, Kesav.
Mar 01, 2010 | Logitech MediaPlay Cordless Mouse
My mouse has quit working. Does it have a battery to replace or something? Do i need to replace the mouse?
If your mouse was working and suddenly stopped, the first thing to do is replace the battery (or batteries). Then push the button on the bottom that is labeled "connect."
That should do it.
Oh, yes--there could be a connect button on the mouse antenna unit, too--the one that plugs into the comptuer.
Jan 16, 2010 | Logitech Cordless Mouse
My VX revolution is missing too much left clicks. Sometimes I need to click 5 times to get 1 click. All the others buttons are working fine. How I can fix this? thks
Seems that the left mouse button needs to be replaced. If you have an old mouse, you can use it as a source of a spare mouse button, & replace the defective button on your VX Revolution.
However, you need to make sure that:
1. The replacement button is identical to the defective one.
2. You have enough skills to solder/desolder electronic components.
Oct 25, 2009 | Logitech Cordless Click! Mouse
Replaced batteries in mouse. Now won't work.
There should be a small button that you can poke the end of a pen with and it should sink- there would be one on the USB receiver and on the mouse. Plus in the USB and hit that button first and then hit the mouse button. On the mouse it will be located on the underside close to where the red optical lens is
Sep 23, 2009 | Logitech Cordless Mouse
Left mouse button doesn't work
You need to check the mouse settings.
If the mouse settings are ok. Then you need to replace the mouse.
For more information please visit the below mentioned link.
http://www.microsoft.com/windowsxp/using/setup/personalize/mouse.mspx
Aug 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse stopped working
If you haven't done this, turn the mouse over and press the reset/connect button on the bottom of the mouse. After you replace batteries it sometimes requires this to be done. If that didn't work, first press the receiver button, then the mouse reset/connect button.
Hope this helps. Bud
Dec 31, 2008 | Micro Innovations PD7250LSR Wireless RF...
My mouse dose not move
There is a connect button under the mouse.
and there is a button on the reciever. Please press both the buttons together for 2 minutes and after this it is supposed to work. However if it is not working replace the battries and do this sync process again.
If still not working contact kensington support they will replace for you.
click on the link below to contact through email.
http://kensington.custhelp.com/cgi-bin/kensington.cfg/php/enduser/ask.php?p_cat_lvl1=8
Regards,
Mohammed
Regards.
Mohammed.
Nov 24, 2007 | Kensington 72219 Mouse
HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Oct 04, 2007 | HP Wireless Optical Mouse
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
