Question about Black & Decker D2030 Iron
MY BLACK & DECKER D2030 DOES NOT POWER ON?
MY BLACK&DECKER D2030 WHEN PLUGGED IN DOES NOT POWER ON. . IS IT THE THERMAL FUSE ? AND WHERE IS IT LOCATED IN THE IRON ? THE THERMAL FUSE.
My black nd decker iron lights up but will not heat.
Posted on Feb 27, 2013
SOURCE: Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
Posted on Jun 16, 2007
SOURCE: Does anyone know how to
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Posted on Mar 07, 2009
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
romsky79
  • 822 Answers
SOURCE: Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Posted on Aug 19, 2009
SOURCE: The Clean light on my Black & Decker Digital
I found a previous answer on FixTa.com that had a link to the owners manual for my iron. The info I needed was there and my problem is resolved!
Posted on Jan 13, 2010
Testimonial: "Exactly what I needed..."
My Black & Decker D2030 Iron fell on the floor and it is leaking water from the tank - can it be repaired?
if the crack is visible and isn't on a part that gets heated then super glue will work 4 you , plus if you cant access the crack a separate 99 cent squirt bottle kept handy will still allow you to use the iron ,just squirt and swipe the iron across the surface ,steam will be made if irons hot enough
Jun 03, 2016 | Irons
Have to hold cord in or it shuts off
I know it's a bit late, but I had the same problem, and fixed it in a similar fashion to kcquidproquo's answer. I have a blog post about it with pictures over at http://racingcow.wordpress.com/2012/05/13/black-decker-d2030-iron-repair/. Hopefully it will help someone.
Oct 25, 2011 | Black & Decker D2030 Iron
The Clean light on my Black & Decker Digital Advantage iron has come on and I can't find my manual. How do I 1) clean it and 2) get the light to turn off?
Jan 12, 2010 | Black & Decker D2030 Iron
We dropped the iron off the ironing board onto the floor, and now it won't heat up.
We located a Black & Decker Service Center here in our town and will be dropping it off tomorrow.
Dec 06, 2009 | Black & Decker D2030 Iron
Aug 19, 2009 | Black & Decker D2030 Iron
Stopped heating
I work for Black & Decker. Any part that someone is telling you to purchase for that iron isn't from Black & Decker. Their irons are no designed to be repaired. If the iron is no longer heating, it needs to be replaced. Please call our customer service department at 800-231-9786 so that we may determine your warranty status.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 20, 2009 | Black & Decker D2030 Iron
Iron stopped working suddenly
perhaps the thermostat is sticking.as irons are cheap to replace i would try cleaning /soaking the tank to remove lime scale. or strip the iron down checking thermostat and conections.
May 01, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Iron is plugged in but does not heat up. I have tried multiple outlets
check the thermostat roll switch it must be turned down to off mode select the cloth type u want to iron thten it should work.
Apr 22, 2008 | Black & Decker D2030 Iron
Iron just stopped getting hot
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very cheap and it would be well worth replacing. Hope this was helpful.
George
Apr 16, 2008 | Black & Decker D2030 Iron
Black & Decker D2030 Iron Logo
533 people viewed this question
Top Black & Decker Irons Experts
tfelton3
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
