Question about Brinkmann ProSeries 810-6330-W Grill
I have a brinkman pro series 8534 that i bought from home depo.it was one that was sitting outside for a while.i got it for a 100 bucks but i cant get it to light,bought a new hose and regulator but s
I have a thirty day store warranty
bbmcdonald
  • 14 Answers
SOURCE: where does the battery in a brinkman pro series
Whereas I can't help you with the exact problem as I am unfamiliar with this model, you can write, call or email Brinkmann's Customer Service where they can point you in the direction of where to download the instruction manual you need. Shouldn't be hard at all.
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Posted on May 30, 2010
bbmcdonald
  • 14 Answers
SOURCE: instructions on how to put a brinkman gas grill
It might be best to just contact Brinkmann's Customer Service Department first. They should be able to either send you a Manual with snail mail OR point you to a link where you can download a copy of the instructions needed. Good Luck!
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
  • 4736 Answers
SOURCE: Just purchased new Brinkman 5
First, check the gas line hose from the tank to the grill. Look for kinks or twisting that would restrict the flow of gas to the burners. If you find any, turn the gas tank valve OFF, disconnect the hose from the tank and straighten the hose, before reconnecting it to the tank. Then open the gas valve Very, Very Slowly, until it's fully open.
If you didn't find any kinks or twist, do the following:
1. Turn the gas tank valve OFF, Disconnect the hose from the tank and wait 5 minutes.
2. Turn on any pair of burners to High for io minute and then turn them OFF.
3. After 5 minutes has elapsed, reconnect the hose to the tank.
4. Open the tank valve VERY, VERY, SLOWLY (Slow motion, slow) until it's fully open.
5. Light the burner farthest from the tank first and turn it to HIGH. Does the flame height look
correct? If so, light the remaining burners the same way. Do all the flame heights look correct?
If so, you solved the problem!
Hope this helped you . Please let me know and Happy Grilling.
Posted on Jun 19, 2011
cadesertmax
  • 274 Answers
SOURCE: I HAVE A BRINKMAN 1415
This is a classic symptom of a failing LP regulator. Replace the regulator and hose to the LP tank.
Posted on Jul 04, 2011
  • 4736 Answers
SOURCE: brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Posted on Jul 05, 2011
Spout on delta faucet 21925lf-ss will not turn back and forth
THERE IS A BALL JOINT INSIDE THE FAUCET THAT YOU WILL NEED TO REPLACE YOU CAN GET A REPLACEMENT FOR IT AT LOWE'S OR HOME DEPO AROUND 5 BUCKS.
Sep 30, 2014 | Delta Plumbing
I have a brinkmann 3 burner grill, the middle burner flames, but the outside ones do not, i just bought it today. How do I light the outside burners?
I am not sure, but I think the Brinkman uses the ignitor to light one burner and the other burners light after the first one allowing the flame to "crossover".
Gary
Sep 18, 2011 | Brinkmann 810-8410-S Stainless Steel...
Brinkman grill 3 burner pro series 8300 won't
Jul 04, 2011 | Brinkmann Grilling
Which is the right rotisserie for the Brinkman 8534 Gas Grill? Where can I purchase it and how much does it cost?
You can find and purchase the rotisserie on Brinkmann's website. Click on the Accessories tab and then enter the correct model number for you grill.
http://www.brinkmann.net/home.aspx
May 14, 2011 | Grilling
I threw the brinkman pro-series 810-8535-sb manual away by mistake. Can I print one via online?
I don't see a 810-8535-sb manual online. However, you can get the manuals for other Brinkmann Pro-series grills from their website: http://www.brinkmann.net/my_grill.aspx . The 4 burner 810-8533-S seems like the closest match. The direct link for this manual is: http://images.brinkmann.net/docs/pdf/810-8533-S.pdf . If you wait a while, the manual for the 810-3535-sb may become available through the My Grill site.
I hope this helps.
Apr 19, 2011 | Garden
How do i install the rotisserie on my grill..it is a pro series 8534...there are no pre-drilled holes and there is no way of closing the lid on the pit while it is cooking,,there is a slot cut out on the...
Buy the Brinkmann Universal Rotisserie Kit model #812-7102-S for $49.95. It uses 2 screws to attach a bracket to the existing tapped holes in the grill. It was that easy! I purchased my grill and the Rotisserie at Home Depot.
Oct 18, 2017 | Brinkmann Grilling
I am trying to order a brinkmann pro series 2600 owners manual, i also need a list of parts for this grill, and i cannot find the link i need to do so.
Brinkman pro 2600 parts and manual issue.Follow my advice,I already did the research.Click on to Brinkman website, plug in your model # and you can download in PDF the original owners manual for free.Secondly call them and leave your phone number for return call.You will find most of your parts even though they are not listed on website and cheaper than after market sites.
Apr 11, 2011 | Garden
Instructions on how to put a brinkman gas grill
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
Jun 27, 2009 | Brinkmann Stainless Steel All-In-One Gas...
Mabe gas range
I HAD JUST PURCHASE A MABE 30' GAS FREE STANDING RANGE AT A LOCAL STORE HERE,THE BURNERS WERE ABSENT BUT I WAS ABLE TO SOURCE THEM AT THE MAIN BRANCH,I AM ALL THE WAY IN JAMAICA.I HOPE YOU CAN SOURCE IT,IF NOT FEEL FREE TO LINK ME UP AT fidel_perry28@hotmail.com,i will pass on the relevant info.good luck.
FIDEL
Jul 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Brinkmann ProSeries 810-6330-W Grill Logo
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
