Question about Kyocera Mita FS-1020D Laser Printer
Kyocera FS 1010 printer. Not printing even with new cartridge
Good morning,
I have a Kyocera Mita FS 1010 printer. I have just replaced the cartridge but the printing is so faint that I cannot read it. The cartridge is new.
Is there something else I should be checking?
Thank you.
Brenda
    New Friend:
    Problem Solver:
  • 6 Answers
Most probably you are facing this problem as the printer is full of paper dust and debris. So it is needed to be clean.Here is how you should clean the printer. Follow the steps and you should have all the printing issues solved.
1.Remove the printer's top and front covers.
2.Lift the processing unit together with the toner container out of the printer. The drum in the processing unit is sensitive to light.
Never expose the drum even to normal office lighting (500
lux) for more than five minutes.
3.The supplied wiper cloth should be used to clean dust and dirt away from the registration roller (metal). Be careful to avoid touching the transfer roller (the black roller).
4.Charger cleaner knob (green-colored) should be slid back and forth 2 to 3 times, return it to its CLEANER HOME POSITION.
5. After you finish cleaning, put the processing unit back to the printer and close the front cover.
If you have followed all these steps, u should be facing printing issues no more.
Still, if you have problems, to know your printer better just click on Kyocera printer catridges
or go to-
Kyocera Toner Cartridges
Posted on Jul 22, 2017
  • 77 Answers
May be moisture.just switch the dehumidifier on for some tine.
Posted on Feb 10, 2009
Kyocera fs-1010 printing problem
Specify the type of paper you are using in driver preferences.
Oct 14, 2015 | Kyocera Mita FS 1010 Laser Printer
My printer prints 1/3 part of the document. Even when I disconnect and print a self test print using the green button it still does the same. What could be the problem? I do I solve it? I am worried.
The problem is with interface cable. Remove the cable and connect it again. Change the ports while connecting the cable and try to print the document. If this does not work, please visit kyocera mita site and contact the dealer for rectification.
Webmaster
www.incomeinnet.com
(An online encycopedia on earning money through internet legally)
Jun 14, 2011 | Kyocera Mita FS 1010 Laser Printer
By Kyocera Mita FS-1020D printer has had it cartridge changed and his just printing a grey smear on the paper and no readable information
is the cartridge a genuine Kyocera cartridge? I had similar problems on some models with the cheaper generic products. had to strip and clean the whole process unit to rectify the problem.
Jan 14, 2011 | Kyocera Mita FS-1020D Laser Printer
Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Jun 25, 2009 | Kyocera Mita FS 1010 Laser Printer
Kyocera mita fs 1010- it prints on the bottom of the page only
sounds like the rollers that feed the paper in is dirty or is completely worn... clean with rubbing alcohol and clean cloth
Apr 12, 2009 | Kyocera Mita FS-1030D Laser Printer
Kyocera Mita FS 1010 every few days it prints out all the pages
Format the harddrive, or go to the properties and change the setting that says leave copy on the harddrive, if all this not working try to initialize the memory and you will be fine.
double check on the driver properties check if it says direct printing or it keeps any copy on the machine.
Regards
Feb 13, 2009 | Kyocera Mita FS 1010 Laser Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Kyocera FS 1010 is printing blank pages
You may need an imaging unit. VERY expensive.
Sep 12, 2008 | Kyocera FS-4000DN Laser Printer
Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Kyocera Mita FS 1010 Laser Printer
Kyocera Mita FS-1020D Laser Printer Logo
863 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
