I dont have any idea how to get this to work but i cant get them to link any ideas?
SOURCE: remote controle codes
Try this website: http://www.thompsontv.com/rcarc.html
Hope these ones work, thanks
SOURCE: Can't find codes for universal remote -- purchased for Vizio TV
Unfortunately, there does not seem to be any truly 'universal' remotes and we have two that won't 'learn' from the originals either.
They should be called 'multibrand' remotes.
Use your Vizio model number of your set and try here:
Remotes
This seems to be the best site but they are also not infallible.
SOURCE: bush dfta16 set top box device code
What is the model number of the remote? It seems to me that Bush may not be a supported device.
SOURCE: need to program my rca
HI,
Direct
Code Entry:
Find the code your
device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX
position, press and release AUX first and then press the device type to be
programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the
device on, press another button to test (volume control/power button).If it
does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps
to set remote without codes
Code
Search:
1. Turn on
the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX
programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using
the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down
list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
