Question about Maxi-Cosi Cabrio Red Flame Reflection Infant Car Seat
We have just had our 2nd Child and strated using our current Maxi Cosi Cabrio Fix Seat with Iso Fix base. However, it has stopped clicking into the base! We know it previously worked, but the small
Iso Fix Base
  • Maxi-Cosi Master
  • 1,629 Answers
Hi
The Maxi Cosi CabrioFix carseat can be used with the EasyFix or the FamilyFix base (both fitted with IsoFix)
In the event that the seat will not click into position on the base it will need inspection / repair work.
If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking it in for chargeable inspection / repair work required.
If you're outside the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
Posted on Feb 17, 2013
lingIT
  • 105 Answers
SOURCE: Maxi-cosi car seat won't fix to EasyBase! Help!
hi chezfeaseys..here's a link for a manual..hope it helps..good luck!!!
http://www.instructions.maxi-cosi.com/download/cabriofix.pdf
Posted on May 16, 2009
Babycare_nl
  • 21 Answers
SOURCE: Have purchased Maxi Cosi baby restraint with Easy Base - Iso fix,
The Maxi Cosi CabrioFix and EasyFix can only be used with IsoFix or the seat belt on (preferrably) the back seat. Please don't alter the mounting system of the seat as it will give unpredicable results!
The Commodore name has been around since 1978 so it is possible when you own an older Commodore you won't have any means to fix the Maxi Cosi seat.
If you do have IsoFix and/or seat belts in the back seat then please elaborate on the exact nature of the problem.
With kind regards,
Babycare.nl
Erwin de Raad
Posted on Jun 23, 2009
greenspan
  • 1734 Answers
SOURCE: lost instructions for use manual maxi-cosi cabrio infant seat
Ask here, they can get you most Maxi Cosi manuals.
Posted on Jun 27, 2009
  • 419 Answers
SOURCE: maxi cosi cabrio fix fitting to renault laguna
I would suggest that you have this fitted by a trained car seat specialist, but you can check the compatibilty on the Fit Finder on this link.
http://www.maxi-cosi.com/maxicosi/carselector.aspx?language=gb-en
I hope this helps;
Posted on Oct 12, 2009
SOURCE: Is Maxi-Cosi Mico Base compatible with CabrioFix?
No, they are not interchangeable.
Posted on Jan 05, 2010
Does maxi cosi cabriofix easy base require anything to be removed from it before fixing it? we cant find where the button is that fixes it to the seat
Hi
Can you clarify - what button are you looking for?
The EasyFix base is fitted into the vehicle using the IsoFix points OR the 3 point seabelt. (Never both) The carseat then clicks onto the base and the metal rods on the underside of the CabrioFix carseat are grabbed by clamps on the base.
May 26, 2012 | Maxi-Cosi Maxi Cosi Mura 3 with Free...
Hi, I would like to ask a few questions: 1. Does the Maxi Cosi Cabrio car seat fits only to the isofix base, or can it be installed to the mico base as well ? If it does, the only difference is that the...
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
Aug 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
My daughter is only 18lb's but seems too tall for the maxi cosi cabriofix. when can she move in to her maxi cosi axiss???
You should keep your child in her Cabrio carseat unless she exceeds 13kg OR her head is higher than the back of the carseat. Make sure that you have removed the newborn support and head hugger too as this can free up a lot of space.
If she is too tall for the Cabrio and is at least 9kg and can sit un-aided for 20 mins, she can move up to the next seat (group 1), this would be the axiss.
I hope this helps.
Oct 24, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi cosi cabrio fix fitting to renault laguna
I hope this helps;
Oct 07, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
With kind regards,
Babycare.nl
Erwin de Raad
Jun 17, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
May 12, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Which car seat fits the Quinny zapp
Hi, all the maxicosi carseats will fit onto the zapp using the adaptors that come with the zapp pushchair (but not the newly rebranded bebe loola).
The difference between the maxi cosi cabriofix and the ordinary cabrio or citi is that the cabriofix can be attached to the maxicosi in-car seat base (easybase or easyfix), whereas the cabrio and citi can only be fitted in the car using the cars seatbelts, they wont attach to the incar base. Hope I have helped a bit x
Aug 31, 2008 | Quinny ZAPP Stroller
Maxi-Cosi Cabrio Red Flame Reflection Infant Car Seat Logo
82 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
