Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
The monitor comes on but then shuts off after ten minutes
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Forgetting that the computer was on, I went to turn it on and shut it off while in sleep mode. The screen won't work.
A monitor does not normally save any states such as sleep. If unplugging the monitor from the power source for ten to twenty minutes and re-plugging it in does not fix the problem check and see if the monitor's menu comes up.
Even in sleep mode, the menu for the monitor should show. If it does, try resetting the monitor to factory default settings. If the menu does not show up, then there is an issue with the monitor.
Jul 04, 2012 | Dell Computers & Internet
Hi the sceen goes black when it is switched on for ten minutes if I switch it off for a few minutes the sceen comes back on. It will then shut off again after a few minutes. Thanks Alan
This is due to the inverter for the backlight, or the backlight itself going bad. You are going to be better off replacing the screen unless you are handy with electronics.
Sep 08, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Auto shutoff d300 nikon to save batery on case of forgoten shut down
If you navigate through the menu system, you will find several items of interest on the Custom Settings menu.
Item c2 controls how long the exposure meter remains active when no operations are performed. It ranges from four seconds to thirty minutes, and also has a "No limit" option.
Item c4 controls how long the monitor remains active when no operations are performed. It ranges from ten seconds to ten minutes.
Jan 13, 2010 | Nikon Cameras
My 441 model monitor heater kicks on but cuts off in about ten
Mine cut off also. I thought it was the wall plug. But as it turned out, I took the cover off the back, cleaned the filter (kinda like a blow dryer clogs in the back) and it is working fine now..... Hope that helps...
Karen
Jan 04, 2010 | Heating & Cooling
My car wont start
sounds like security shut down which will start run for second then shut down after several time the security will shut down completely.......you can try what is called the relearn proceedure..this is what you dealer will do...might have to put battery charger on car first... then put key in ignition and turn to the run position do not crank leave it in the on position for ten minutes...... then turn key to the off position then back to the run position again for another ten minutes.....for the last time turn key off then back to run for the last ten minute cycle.... after the final ten minutes is up turn key to off position then attempt to start... let me know
Aug 31, 2009 | 1997 Chevrolet Cavalier
HP mx 70 Monitor
This is a problem usually with the Power Supply unit inside the Monitor. Often it is the Electrolytic Capacitors arround the Heatsink area. They dry out and go faulty.. It is generally a job for the "Shop" I get them all the time... But in saying that intermittent faults are the hardest to find.. If you do take it to a shop, ensure you get a firm "Quote" and explanation B4 proceeding.
May 14, 2007 | HP mx705 17" CRT Monitor
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
