I have a 72" mitsubishi tv that somehow got locked. Ext. 1 and 2 I have never had a code I never locked it. What can I do to unlock this? David Scott Hunter 257 Baltimore Rd. Huntsville, Ala. 35810
I have not resolved the problem. according to your tech. I am going to have to call a local
Mitsubishi service tech to come to my home. He says that I need to install a chip of some kind...
Hence problem not solved, yet.
David Scott Hunter
Posted on Jan 19, 2009
My tv is locked and asking for a an unlock code. I have never had a lock code on the tv since i bought it several years ago. How can I reset or bypass this feature. BTW mt TV is a 48-50" projection...
Hello
I thinks that you have its original remote handset with you now, and posts this solution. If you don't have it, either buy a new original remote handset or try to get it from any of your friends and relatives, who owns the same model of Mitsubishi Tv, you have now; only to unlock it. After unlock, you can use any other remote control.
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Sep 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I HAVE A MITSUBISHI (MEDALLION MODEL TV).THE V-CHIP IS ON AND I CANT RELEASE THE V-CHIP BECAUSE A CODE IS NEEDED. IS THERE AN OVERRIDE CODE THAT CAN BE USED TO CLEAR THE VCHIP?
Oct 02, 2008 | Mitsubishi Televison & Video
I am locked out of EXT 1 and do not have the remote control is there a default code to unlock the TV?
ok unplug tv for 5 min then plug back in and press and hold the power button for ten seconds this should reset the tv!
hope this helps
Dec 11, 2008 | Televison & Video
Locked out of older Mitsubishi VS4503R. Need owners manual/help!
If you are locked out of the inputs, you need a original Mits remote. Push QV and the 9 button simultaneously to unlock temporarily. Some models its the SQV button and 9. This will let you get in to change the code. You can also get a simmilar issues with the active AV network turned on, it will lock it to a set input (ie input 1). Try going into the menu and turning the av network off.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
My Mother has the VS-5003R big screen television that she purchased back in 1990. the television portion works fine but the ext-1 and ext-2 inputs are locked from a code that probably died with my father...
I have the same tv and same issue. I found chain of notes indicating that you can clear the lock by pressing 9-QV (two buttons) on the original remote at the same time. This works... however if you change the input again the EXT1 and EXT2 inputs will be locked again. It would be really nice if you can remove the lock feature completely.
Aug 07, 2008 | Mitsubishi Televison & Video
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Locked ext inputs
I'll give you the master reset, with set on, and from the remote hit Menu-1-2-7-0 this will bring up the Intilize screen and the word Initlize should be highlighted, if it is hit enter on the remote, this is the factory default settings so now if the set ask for a parental code it will be 0000
Nov 06, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Electro Med Services...
