Televison & Video Logo
A
Anonymous Posted on Jan 01, 2013
I have a sony tv and xfinity remote
Sony kv-27566
5 Related Answers
Anonymous
  • 232 Answers
  • Posted on Jan 04, 2008
SOURCE: Sony KV-27V55 27" TV with no remote
Nope, you can order a new remote here if you want to pay the price, around $65 plus s&h www.wehaveparts.com theres no other way to activate service mode, BMW Rider
Anonymous
  • 129 Answers
  • Posted on Mar 11, 2008
SOURCE: Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
A
Anonymous
  • Posted on Oct 04, 2008
SOURCE: sony kv-21x1u
Press and hold for a few Seconds the 2nd Button from the left on the front of the TV. The auto tune menu will appear on the bottom right of the screen. Wait until it disappears and then check the channels by using the buttons on the remote.
Anonymous
  • Posted on Nov 19, 2008
SOURCE: tv remote codes
I have a Zenith universal remote that i want to program to a sony 27 inch Trinitron, what are the codes?
Anonymous
  • Posted on Jun 01, 2009
SOURCE: Sony TV Trinitron is on standby
standby light flashes tv wont turn on
1helpful
Programming code for Samsung TM-59 AA64-50236 remote to pair with Sony Trinitron KV-32S42
not going to work. That remote is for a DVD, and not reprogrammable.
this is your Sony Remote
Used General Replacement Remote Control For Sony KV ...
www.amazon.ca > Replacement-KV-32S40-KV-32S42-...
Used General Replacement Remote Control For Sony KV-32S4 KV-32S40 KV-32S42 KP-V46S55 KP-XBR48 Plamsma LCD LED HDTV TV television: ...
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
4answers
I need a comcast remote tv code for a AMP'D tv
For the comcast xfinity remote use the philips code 11454 from the lcd tv section. That is the code that I got to work
I can't get my xfinity remote to work on my new Sony Bravia tv.
Call Xfinity to get another Digital HD DVR mine is a RGN200N it has a programmable remote you can program 3 devices using the codes provided in the guide. Does the box that remote controls offer HD? Or just digital TV?
1helpful
2answers
Need Comcast remote code for sony trinitron KV27FS100L
These are the codes to check. 10000, 10011, 10273, 10353, 10834, 11317, 11400, 11685, 11786, 11791, 11904, 11925
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Video Labels stay on - Sony TV Model KV-32V16
Press Display / ' i ' button TV original remote and on-screen display will disappear.
I repeat, you need Sony TV original remote to do so, universal remotes do not have such button.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
