I opened my computer cabinet and now I have to hit F1 everytime the computer restarts?
How do I clear this problem?
  • 7,627 Answers
Opening a computer case should not cause a problem, that I am aware of? Is the case replaced/closed? F-1? Why? What kind of computer? What OS?
Posted on Jan 02, 2013
How do you disable the on board videocard on a hp p6130f?
Turn on the computer. Press the left "Ctrl" key. When the start-up menu appears, select "Safe Mode" and press "Enter." Once the computer enters safe mode, click the Windows "Start" button. Go to "Settings" and open "Control Panel."
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
Aug 26, 2012 | HP Computers & Internet
EVERYTIME I TRY TO START MY TOSHIBA LAPTOP UP,I JUST JKEEP GETTING A MESSAGE SAYING BOOT MGR. I PRESS DEL,ALT AND CTRL BUT THEN THE MESSAGE JUST REPEATS. AND I DO NOT HAVE ANY BACKUP OR RECOVERY DISCS.
Right after you turn on the pc, go into the bios. Usally by hitting f1, f2, or del. just keep hitting those 3 keys as it boots. Once in the bios, find the boot manager option and disable it. hit f10 to save changes and exit and your pc should restart.
May 15, 2011 | Computers & Internet
I cant get into the BIOS from Portege 3500
Keep hitting escape while starting up. Message will say there is an error and hit F1. Hit F1 and you'll enter bios.
Apr 18, 2010 | Toshiba Portege 3505 Tablet PC
I just had the panel rewired fro f51 now i have f1
F1 is a primary control failure. When I get my F1 I hit pause/clear and then start - it usally begins its cylce then bumps back to F1. If I do this about 3-7 time it will clear. Then on rinse we go again. Some days I have a 3-F1 restart and somedays it is a 7-F1 restart. Just depends on the day. No rhyme or reason. I know I have to replace the main circuit board but $160 + labor is not what I want to do, so I fuss over the F1 and move on.
Feb 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How to enter into BIOS when trackpoint was broken.
Hi there.
Its something to do with the trackpoint, possibly the cable has become loose.
* If an emergency power down is made by switching the system off during or while an application is open, then immediately switching the system on creates a 8611 error.
* Repeatedly turning power off and back on without properly shutting down or allowing the system to shut itself down.
Solution
Wait at least 6 seconds or longer after shutting down the system or before restarting to correct the 8611 error.
See if that gets rid of the error, if not it could be a loose cable to the trackpoint.
Good luck
Jun 01, 2009 | IBM ThinkPad 600X Notebook
Penryn1600sli CMOS check bad error
That sounds like a classic case of a dying cmos battery.
Dec 18, 2008 | ASUS Terminator A7SC (TERMINATOR...
Boot up error showing "chassis has been opened"
Here is the solution. I had the same problem.
Chassis Warning
"Warning your chassis has been opened. Press F1 to continue. Press Del to enter setup menu."
Resolution
Enter Bios
Goto Intergrated Peripherals
Goto Onboard I/O setup
Find "Chassis Opened warning"
Set to “Disable”
Press F10 to save and exit changes
That all there is too it.
Nov 30, 2008 | Computers & Internet
Default code F1
if you physically forced door open then started f1, its possible that there is no issue and you can reset it. F1 is a code for water leak... if you can remove the lower drawer from the cabinet, youll find water in the lower tray, youll need to dry up this water in order to have the f1 code stop
Nov 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Access BIOS
what computer brand and model is it ?
Robert
Sep 01, 2008 | IBM NetVista PC Desktop
How to re-set computer to original setting
Ente in BIOS setup and choose the option load default values.
to enter in Bios press DEL , F1 or F2 Depends on the Bios
the POST screen will show u the key for entering in bios .
other method is u open the case of ur PC cabinet and put the Cmos jumper in Clear mode for few seconds aand put again in its origional state.
Jan 19, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
