Question about Toys
I put my kids two plastic cups and two swrily straws in the dish washer and when I went to go use them that is what happen to then they unswriled and will not fit in cup
    Problem Solver:
  • 10 Answers
Option 1: Deluxe Refurbishing
  1. Get some stiff pipe-cleaners from the craft store. You may need to braid them together to end up with one that's thick and strong enough to use.
  2. Boil a few litres of water.
  3. Lower the straws into the boiling water. They'll soften and uncoil.
  4. Using tongs and wearing water-proof and heat-resistant gloves, pull the straw out of the water.
  5. Feed the straight straw over the pipe-cleaner.
  6. While the straw is still hot and soft, coil it around the outside of the cup. This is your first pass. When the straw sets, take it off the cup.
  7. Put the straw back in the boiling water. The pipe-cleaner should hold it in the correct (roughly correct) shape.
  8. Set the cup on a low pan, like a bake-tray. This is to catch spills. DO NOT SKIP THIS STEP!
  9. Push the softened, coiled straw into the cup, twisting the straw to tighten the coil. You may use tongs or a butter-knife to push the straw down in the cup.
  10. If the straw gets stuck, and starts to set, fill the cup with boiling water. BE VERY CAREFUL. Pour the water back into the kettle or pot, then keep working the straw into the correct shape.
When all of this is done, you can pull the pipe-cleaners out of the straw. Voila! And if you're feeling daring, you can use this method to create a completely different shape to the straw. If you do, keep the pipe-cleaners handy. You'll need them to clean the interior of the straw (it gets gross otherwise).
Option 2: Quick and Dirty Refurb
Boil the water, heat the straw, and put the cup on the bake-tray.Fill the cup with boiling water.Push the floppy straw into the cup, twisting it into a coil as you do so. You may use a dull knife to arrange the coil of the straw.
The coil will be pushed to the bottom of the cup, and won't have the nicely separated spiral of the original - but it will work.
Posted on Jan 01, 2013
2 Suggested Answers
  • 22 Answers
SOURCE: Munchkin sippy cup - too difficult to sip!!!!
is there a rubber stopper that may be put in wrong try taking it out and putting it in the other way
Posted on Apr 03, 2009
I have fridgdere dish washer every time I put the dishes in the washer it comes out foggy and discloured pls reply waht to do.
Clean out any junk in the washer. Then put in some new rinsing agent. That should work.
If it's still a problem, put a cup of vinegar into the bottom of the dishwasher while doing a load of glasses and other light dishes . These should come out sparkling and it may help clean some unseen junk in the washer.
Oct 16, 2010 | Dishwashers
Where do you put the dish wash detergent for my dish washer!
Hi, for most dishwashers the detergent cup is behind a little door in the door of the dishwasher.. snap open the door and place the detergent in the cup while the door is open and down, then close the little door and then close the dishwasher door...
then you are ready to roll...
DishwasherRepair Problem Detergent Cup does not Open
heatman101
Sep 19, 2010 | Dishwashers
My dishwasher is leaving a film all over the dishes
you might try to put one cup of vinegar in the washer and run the wash cycle with this in it no dishes in is while you are doing this. We live in the country and my wife had this happen and we used vinegar and it stopped this lime build up. Not an expert on this but it worth trying.
Jul 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Instruction for the top dish rack were missing from my order. The rack is for Whirlpool quiet wash plus dish washer. Do you have the instructions?
The top rack is generally for things like glassware, bowls, cups, saucers, and plastics items. Smaller and more fragile pieces go on the top, bigger items on the lower rack. This is the general rule for all dishwashers.
Oct 13, 2009 | Dishwashers
Maytag 7500 Water in cups for bleach & softener
you should have a small amount of water in the resivoir this is part of the siphon system
but you do want to keep it clean every 4-5 loads put it through the dish washer
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Makes a loud buzzing noise when running, think it is coming from the lower spray arm
My dishwasher (very basic GE model) did this once. The buzzing only happened when it was washing the dishes, not during drain or fill parts of the cycle.
In my case, the issue turned out to be a bit of plastic (part of a drinking straw) that was stuck in the pump assembly. Whenever the pump was on, this bit of plastic was getting dragged over a metal filter plate, and sounded a lot like a kid with a card clipped in the spokes of a bike.
Good news was that I didn't need to buy any parts, simply disassemble the pump housing and pull out the plastic.
Bad news is that it took me a few hours to get the dishwasher out, apart, back together and re-installed.
Good luck with yours!
Jul 31, 2009 | GE Dishwashers
Squeaking noise from left side, sounds like spring on low speed. would mounting on a platform do any good
I had a problem with the Left Spring the hold the drum up. I took the cover off and started the machine to be sure that I got the right squeak.
The soap dispenser was in the way to get some WD40 to the spring. I would have to remove the front panel to get at the spring. I didn't like that idea.
I got a brainwave. I fill a cup with some WD40, got a plastic straw with a bendable neck and **** up a little oil, pinched the straw to stop the WD falling out, I slipped the straw down the side of the dispenser right over the spring and let it drop.
Work like a charm, no more squeak
Feb 18, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Despenser cup - Kenmore dish washer
hi
the dispenser will always open when the washer goes through it's regular cycle. I would recommend to only use powdered soap, that is what the washer was designed to work best with.
Mar 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Washer repair
The pins are supposed to fall out thats why there are plastic catch cups. Its designed for shipping with the pins put back your washer will not work properly and may damage it if continue to use it with the pins.
Dec 02, 2006 | Kenmore 20172 Top Load Washer
Toys Logo
153 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
