Question about Ematic Em804 MP3 Player
My device doesn't on
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
Cant pick up wireless internet from hub
It doesn't sound like you have a wireless router or wireless access point. If you have a hub or switch, that doesn't give you wireless capability.
Many wireless routers will have antennas on the back of the unit (that is one way to tell) but it's not sure since some don't.
You can post back with the make & model of your router, etc. for device specific help.
Mar 16, 2012 | ASUS Eee PC 1000HE Netbook
How to activate my webcam on HP COMPAQ 8510p? It has Windows 7, 32-bit operating system. And it doesn't have any quickplay or mediasmart as far as I have researched. Where can download a program...
Hi
Follow the instructions below to use your webcam
Click on Start then >Control panel>hardware and sound >device manager>imaging devices>web cam....enable it
Another way is to use a IM application like:
Yahoo messenger,MSN Messenger,NetMeeting,etc.
They will have video capabilities that will work with your webcam.
If this doesn't work, then reinstall your drivers.
Please take time to rate me
Sep 06, 2011 | HP Compaq 8510p Notebook
I have a n5030 dell inspiron and i use to connect using wifi. The last time that i did use my laptop the wifi device is not working (the system says that there is no wifi & bluetooth devices). I use...
Make sure your wifi switch is turned on. If that doesn't work, try taking out the battery of your laptop, waiting at least 10 seconds, and then rebooting. If THAT doesn't work, try system restore and take it back until before your wifi quit working.
Aug 22, 2011 | Computers & Internet
12,000 btu emerson quiet kool 220/230 about 9 years old, need to know $$ per hour to run with total kw/h cost $0.30 (this includes all taxes and fees). Sorry can't provide wattage or amps (no manual...
If your device doesn't list wattage, but it does list amps, then just multiply the amps times the voltage to get the watts. For example:
amps x volts = watts x .30 if you dont have any information you are sol.
Jul 06, 2011 | Emerson Quiet Kool 10NW16K Air Conditioner
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
Recently I bought the Canon Ixus 220 HS compact camera. With the camera I received some software among other things Zoombrowser ex. Regretfully this program doesn't work properly from the start. When...
Is your Camera detected when connected to the PC via the PTP in the Device Manager? Check your "Device Manager". In Windows 7, sometimes the camera is not detected, but you can try "Workaround when the camera cannot be detected by Windows 7(when connected via PTP)". If the device is not detect in the Device Manager the software will not work.
The update is only for the software ie Zoombrowser(Win7x64) -> update to version ZoomBrowser EX 6.7.2 Updater.
Hope it helps & good luck.
Jun 08, 2011 | Computers & Internet
Stopped working.
You don't have say in details. but I'll try to solve your problem. If both are not working then detach them both and replugged again to the system. Then reboot the system. If it doesn't work then check the device manager settings and external device settings in Bios settings. If those device are wireless then check first the receiver battery and change the battery. Better if you can place another set of keyboard & mouse to the system to confirm that there don't any problem or not getting hang the system.If it doesn't solve your problem then go to the nearest service center for repair or purchase a new.
Apr 28, 2011 | Logitech Computers & Internet
Ematic Em804 MP3 Player Logo
24 people viewed this question
Top Ematic Audio Players & Recorders Experts
Lawrence Oravetz
Are you an Ematic Audio Player and Recorder Expert? Answer questions, earn points and help others
