Question about Sony VAIO VPCF13YFX/B Laptop Computer - Intel Core i7-740QM 1.73GHz, 6
My Sony VAIO laptop stops suddenly for no apparent reason. It may run for 5 minutes or 20 minutes and stop. It may take it another couple of hours to reboot itself. The fan, battery and AC supply are
Model PCG-81115L
  • Sony Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 01, 2013
  • udonta
    udonta Jan 03, 2013
    Thanks. I checked the laptop again, dismantled it and looked around. The capacitors and power source are all intact. I am puzzled. Thanks a million for the input. Much appreciated.
  • Brian Sullivan
    Brian Sullivan Jan 04, 2013
    computers can be temperamental things sometimes just unplugging then replugging leads and plugs , devices can fix the problem it might be a problem with the pcb board
Some letters don't work on my sony vaio
Check the keyboard. If it is defective replace it. You might want to hook up a USB keyboard to ascertain that the laptop keyboard is the one that is defective.
Aug 12, 2014 | Sony VAIO Notebook
No operating system on my Vaio E series laotor with windows 7
Install new windows os using pendrive booting method.
Aug 14, 2017 | Sony VAIO VPCEE31FX Notebook
Sony VPCEC1M1E keeps freezing
This is probably due to bad ram memory, remove one stick of ram and use the laptop normally, if no change, remove the second piece and replace the first.
May 10, 2012 | Sony VAIO VGNBX740NS5 Notebook
My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
Feb 06, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
The fan goes on, loudly, for no apparent reason. The laptop is not overheated. It goes on and off for a few minutes, and then stops. This will happen a few times a day, and only started recently. My...
Sony laptops have a thermostat which monitors the heat internally. When it gets too hot, the fan will turn on, when the unit cools back down, it will then turn off. There is nothing to worry about.
Jan 30, 2010 | Sony VAIO VGN-CS260J/P Laptop
Problems booting Sony Vaio VGN N250E
no more then likely it sounds as tho your hard drive went ..not the mother board.
Jul 23, 2009 | Sony VAIO VGN-N250E/B Notebook
My Sony Vaio stopped hibernating suddenly
go to the control panel and see power options. you will find a solution there. if you dont let me know.
Jul 10, 2009 | Sony VAIO Notebook
Sony Vaio PCG-6h4l laptop turns off for no reason. While using laptop on batteries it works fine and does not power off while using. But while using with electricity the laptop turns off for no reason,...
It could be that the laptop disables it's battery when you connect it with the power supply. When the power supply then fails it won't have enough time to switch back to battery. You'd best first try another power supply, and post back here if that doesn't help.
Jun 07, 2009 | Sony Computers & Internet
Dryer runs for 20 minutes. shuts down. won't start again for 2 hours.
Hi, It sounds like you have a motor going bad. If this is a whirlpool brand models, the motor is about $90.00 to $100.00. If I can assist you further, please let me know.
Thanks
Vic
May 21, 2009 | Dryers
Sony VAIO VPCF13YFX/B Laptop Computer - Intel Core i7-740QM 1.73GHz, 6 Logo
87 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
