Question about Toshiba 50HM66 52" Television
How do you know which board to replace
New lamp, toshiba tech support says it is the ballast. There is the ballast board, and the power ballast board. Not sure which one to replace
C-Dog
  • 84 Answers
SOURCE: ballast
yes, at www.tritronicsinc.com. They are in Maryland and are a Toshiba authorized parts distributor.
C-Dog
Posted on Feb 11, 2008
  • 453 Answers
SOURCE: Installed 2 new lamps, still no picture...
i had the same problem , first ? do u hear any arching noise like spark on the back of u set , if u do thats the ballast , it need to be repleace , now if there is not a spark u may have a bad light engine , need to repleace engine
Posted on May 01, 2008
SOURCE: how to replace ballast in toshiba 52hm84 dlp rear tv.
how do I change the lamp?
Posted on May 15, 2009
axeist
SOURCE: 52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Posted on Jan 18, 2010
ladywinn
  • 5138 Answers
SOURCE: Toshiba 62HM196. Original tv
Lamp needs to be replaced,
Mats has them for $99.00 1-800-628-1118
Posted on Sep 11, 2010
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I have a sony kds 60a2020. the lamp sensor light was flashing and no picture. i bought a new lamp and installed it and now all i get is red power light flashing three times. as much as i can tell am ...
A lot of these had problems with the lamp door; you need to remove the door and take a careful look at it edgewise---heat from the lamp can warp the door.
Notice the small plastic peg on the back of the door--when installed it engages a lever which is a safety switch so set cannot be operated with door removed.
If door appears slightly warped what I do is engage the lever (usually tiny and blue in color) and turn the set on.
WARNING: IF SET COMES ON DO NOT LOOK AT LIGHT FROM LAMP DIRECTLY. If set works with lever engaged you need to replace the door (EBAY has sellers with most of them) and DO NOT OPERATE SET WITH DOOR REMOVED OR REPLACE OUTER SHIELD AS HEAT FROM LAMP CAN DAMAGE THAT WITH DOOR REMOVED.
Before you rate this solution let me know if you have questions or what you find; engaging the lever will either rule the door out or confirm it is your problem.
SD TECH
Jul 09, 2011 | Sony KDS-60A2020 60" HDTV
THE TV IS MAKING NOISE AROUND THE LAMP OF MY TOSHIBA TV 46HM95 THE PROBLEM OCCURS UPON SWITCHING ON BOUGHT A NEW LAMP AND A NEW FUN STILL NO CHANGE AFTER INSTALLING.
U hearing alot of clickings,when the tv turn on?Yes,the board call the Ballast board is dead also.This Ballast board,job is to help, to ignite the projection lamp.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Oct 14, 2010 | Toshiba 46HM95 46" HDTV
I have the 50hm66 tv, replaced the main power supply board, and then the aux. power suppy board, still no lamp (lamp is good), 15 yellow blinks What you think ???
U hear alot of clickings,few mins tv is on?The board call the Ballast board is dead.This Ballast board help to ignite the projection lamp.
Aug 13, 2010 | Toshiba 50HM66 52" Television
I replaced the lamp- now the picture won't come up
U hear alot of clicking,when power on to the tv?Yes,the ballast board,that the board that help to ignite the projection lamp is dead.The Ballast board is dead.Change the Ballast board.
Jul 14, 2010 | Toshiba Televison & Video
Replaced lamp in toshiba 46hm84. still get
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast is the most common failure besides the lamp.The ballast is the one that displays the lamp indicator if it's not able to power bulb or if bulb is not responding.Have a blessed one!
Mar 30, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Just replaced a new lamp. TV tried to turn on/off
Ur tv have a Ballast board that help to ignite the lamp.U hear alot of clickings,that mean the ballast board is dead,not doing it job.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Feb 28, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
HOW TO CHECK BALLAST LAMP FOR 62HM95
Ballast Board Powers Lamp, the 2 plugs on Lamp connect into Ballast
board just follow the wires from where lamp plugs into.
Does Ballast have a ark coming from a componet on board and does the main capacitor Look Vented or puffed up on top?
Remove Lamp turn TV on see if Ballast has a ark coming from a Big Whit/blue writing on it spark cap?
Feb 19, 2010 | Toshiba 62HM95 62" DLP HDTV
My color wheel apparently went out so i had a tech replace. when i got it back it worked for a few hours and the turned off and flashed the 3 leds. so i figured it blew the lamp. replaced that. still...
ballast or smps board (power supply board) or the main board. Had same problem, replaced lamp, ballast and power supply, worked for 2 weeks now front lights flashing again. ordered main board per samsung tech. support.
Nov 05, 2009 | Samsung DLP HL-P5663W 56" TV
My PT-61LCX65 all of a sudden turned itself off and the Lamp indicator LED is blinking once every 5 sec. It will not power up. Can it be the lamp?
That is most probably the lamp. In some case the lamp is fine and the problem is the lamp high voltage board (ballast board).
The most coomon is always the lamp. The lamp cannot be tested . The ballast board must be tested by a technician.
The normal operation in this case is replaceing the lamp that cannot be tested. then, if you are within that 2% of the cases with ballast problem you replace the lamp power board or call a technician.
You can find parts here.
May 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Toshiba 50HM66 52" Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
