Question about Toshiba E-studio 281c Copier
My toshiba e-studio281c is cutting off the edges when i print
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Check and make absolutely sure your paper guides in the trays are closed (tight against paper)
Posted on Feb 15, 2013
Toshiba e-studio 305 copies are cut off how can we reset margin
margins are set from the software doing the printing
look at print options and print preview before you print
Nov 16, 2016 | Toshiba Office Equipment & Supplies
How to print borderless
With a few exceptions, most laser printers will not print edge to edge and there has to be some border on each size. Print on a larger sheet of paper and cut it down.
Jul 23, 2014 | HP LaserJet Office Equipment & Supplies
How to do borderless printing on HP laserjet 1022n?
the hp 1022 is not capable of printing edge to edge for that matter very very VERY few can. the problem is that the printer needs to be able to move the paper through the machine without distorting the printed image and this requires a LEAD EDGE usually about 3-5mm edge to edge down the long side of the paper the printer is able to get quite close to edge at 2-3mm either side but NOT EDGE to EDGE the only real way of accomplishing true edge to edge is to overprint and trim the final page to size.e.g. print on A3 and cut to A4
Jan 29, 2014 | HP LaserJet 1022n Printer
How do you cut off 15mm slices from 60mm lengths of 130mm diameter round bar?
You can't get 4 pieces as u may lost material as cutting.One suggestion: out of a print paper (very sharp edges) u can make a perfect tube (by alignement of the edges)to help u marking the cut (fine pointer permanent cd marker). The rest depend on the tube material and the disc/blade/wire used for the operation.
Oct 21, 2013 | Cars & Trucks
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Can I print with no margins? I'd like to copy to go right to the edge of the paper.
NO!! no copier can do that. only print press can. you can print on 12x18 and cut edges if needed
Sep 21, 2011 | Konica Minolta Bizhub c203 Copier
My Zebra P110i is not printing it's cards correctly, When I print a card, there is always a 2mm blank line gap on the end of the card where the printer has not printed on it. I've cleaned the printer,...
The Zebra P110i printer is an Edge-To-Edge card printer, which means it will print on the card closest to the edge as possible, however there will still be a slight line. Although a 2mm line is too big, should be no more than 1mm, there will still always be a line.
There are some advanced EC (end card) settings that could be adjusted but if the print goes too close to the edge, the ribbon will get cut.
-- The Pros at www.DiscountIDStore.com
Mar 26, 2011 | Zebra P110i ID Card Printer
Why does the top of my picture cut off when i print it
Ladydiw,
Are you trying to print the image to the full size of the paper if so does you printer support edge to edge printing?
If not or if you are unsure try resizing the picture to leave a border round the edges.
Regards
Nick
Oct 26, 2008 | HP Office Equipment & Supplies
Using the cutter
you want to print borderless on a cutsheet media? you just have to select and 'cheat' the printer in the printer properties, in there choose roll on the paper source option then enable the cutter and choose double cut on printer's set-up menu on the panel, then it'll cut before and after the printing to make it borderless from top to bottom and from edge to edge. just be sure that the cutsheet media is long enough so that the printer can still hold the media as it finishes the printing or else it'll be a waste, cause the printer wont finish the image. and take note that the epson sp9600 has a limitation in printing borderless, it'll only print borderless on (12", 17", 24", 36:, and 44") media size only i think there's also 14". trust me it'll work, ive done it! :P
Sep 26, 2007 | Epson Stylus Pro 9600 InkJet Printer
Toshiba E-studio 281c Copier Logo
70 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
