Question about Lexmark X5150 All-In-One InkJet Printer
Only prints the first page of any document I have the same problem with the Lexmark x5150....anyone know how to solve this? I installed and uninstalled driveer countless times...any help would be appreciated... Thank you!
  • bassplay Jan 27, 2009
    Couldn't find a way to change it to Lexmark x1100 but changing it to NTEMF 1.0008 seemed to do the trick!
    Thank you,
    Susan
  • Lexmark Master
  • 684 Answers
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X1100 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
Posted on Jan 21, 2009
Printer lexmark x5150 not print
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Nov 11, 2011 | Lexmark X5150 All-In-One InkJet Printer
On trying to print from computer off the internet to Lexmark X5150 all i get is a page of letters and nothing like what i am trying to print. I have uninstalled and reinstalled the printer and tried...
select the part of the page you want to print with your mouse.
then press file -> print
on page range, set it on - selection.
It will print the selected part.
Jul 12, 2008 | Lexmark Office Equipment & Supplies
Lexmark printer X5150 is printing color images but not typed font? Just installed new b/w cartridge...the color test works fine but can't get a letter to print out...page comes out blank
Try to see how you can restore the settings to default. There may be a setting to don't print text somewhere that got marked accidentally. Check your document type in the settings, it may be set to "picture" instead of mixed type document (I don't know what the setting is called, just that it's there) Also press the stop / clear button after printing an image to return to default settings
If this post helped, please vote.
Jul 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
I bought two new cartridges for my printer but the printer prints funny. there is no color and the black appears faded. my printer is about 2 years old. have any ideals?
Sounds like the jets may be clogged. You may have to run multiple times till they are good. Print a test after each clean and see if that helps.  You can use the operator panel or the Lexmark X5100 Series Solution Center to clean the nozzles. Using the operator panel 1 Load paper in the All-In-One. For help, see page 16. 2 Press Options until Cartridges appears on the display. 3 Press the right arrow until Clean appears on the display. 4 Press Select. A nozzle page prints forcing ink through the nozzles to clean the clogged nozzles. 5 Print your document again to verify your print quality has improved. 6 To further improve print quality, try wiping the print cartridge nozzles and contacts (see page 44), and then print your document again. 7 If print quality has not improved, try cleaning the print cartridge nozzles up to two more times. you can get the owners manual on line at this address:  http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
please rate this and good luck.
Jan 30, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-in-One printer
the following is a link to a library of Lexmark X5150 drivers for all versions of Windows and MacOS.
Click Here
I hope this helps solve your problem. and Please do not forget to rate my solution.
Jul 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Dec 18, 2007 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
