Question about Dewalt Drills
How to install brushes in DeWalt 14 Volt DC970 drill
Need to replace brushes as drill smokes
SOURCE: dewalt dw959 does not work in reverse
tirb
Posted on Sep 22, 2008
rowdy45176
  • 2176 Answers
SOURCE: I think the brushes are bad but I don't have a
Go to Dewaltservicenet.com and in the middle of the site type in your model number and you can download a schematic for the tool and it will show you where and part number let me know if you need more help
Posted on Sep 12, 2009
  • 384 Answers
SOURCE: how do you replace brushes in a dewalt 18 volt
Why do you think the brushes are worn.
Posted on Sep 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to Dewaltservicenet.com and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Posted on Dec 22, 2009
mark24354
  • 776 Answers
SOURCE: How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Posted on Mar 19, 2010
How to change brushes on a dc970
I don't think the motor is serviceable that way. At
DeWALT DC970 Parts List and Diagram eReplacementParts com you can find the motor and pinion for $35 plus shipping and then get the entire drill working again. Had the same problem with one of mine and it was an easy fix.
Apr 10, 2014 | Dewalt 18v Cordless Hammerdrill Dcd970
Dewalt 18v xrp clutch slipping and electrical smoke smell in rear
Yes you can. Depending on the model of the tool it may not be the clutch causing your problem though. On some models the transmission is more likely the problem. Brushes create an ozone smell when the motor runs so that could be the smell. Does it run slow or get hot?
Jan 01, 2012 | Dewalt 18 Volt Compact Drill Kit
I purchased brushes for my 12 volt dewalt drill yesterday at the Dewalt warranty store in Denver. Today I took the housing off the drill and it does not have the same type of brushes in it as the...
Brushes over time will wear down so comparing from the old to new will not look the same. If 18V brushes fit into the your drill then it should be fine.
Mar 24, 2011 | Dewalt DC727KA 3/8" 12v Cordless...
Smoke and electrical smell coming out of motor
Sounds like your "brushes" will need to be replaced. Please see the attahced video for step-by-step instructions.
http://www.youtube.com/watch?v=tECeZi6IfvU
Mar 05, 2011 | Dewalt 18 Volt Compact Drill Kit
The drill was smoking while in use at the rear of the drill
Hi, these units tend to heat up over extended use. It is possible that your brushes have worn down and need to be replaced. The contact area around the commutator, (where the brushes push against), should be cleaned gently with ultra fine steel wool. Also, the gaps between the contact points of the commutator should be free of any conductive dust left behind by your dying brushes. Since the drill needs to be disassembled in order to do this, check any connections for weakness and any more conductive dust that may be shorting something. good luck.
Nov 16, 2010 | Dewalt 18 Volt Compact Drill Kit
My dewalt drill charger started smoking when i put the battery in although it wasn't even pluged in to the wall and now won't work
If this is for the 14 and 18 volt batteries, this is what I found had occured on one model I repaired (I've forgotten the charger model number):
It had a shorted diode (the bad one had obvious burn marks on the pc
board). I used an NTE 5809 diode to replace the original one. BTW you'll need
a Tamperproof Torx T-10 to open the case to access the pc board.
Feb 10, 2010 | Dewalt Drills
I think the brushes are bad but I don't have a exploded view of the drill to know where to install the. It is a Dewalt 18 V. I runs with less power than when it was newer, maybe 50% less and there was some...
Jul 02, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt DWo56 18 Volt cordless impact
all drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
Mar 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
52 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
