Question about Albatron nForce2 KM18G Pro (KM18G PRO 2.0) Motherboard
KM18G pro motherboard power connection, reset sw, power sw, etc.
I removed these leads by mistake and cant get them back on, there are four leads with two connections but one has a split connection ie, three holes with connection on 1st & 3rd hole. there are nine pins to connect to. the leads are orange & white reset switch, black & white power switch, red & white hdd led, green & white power led. my pc is a time and about 8yrs old. any help will be much aprreciated. ecky.
  • eckythump Jan 19, 2009
    thanks to witchunter for replying to my post, but unfortunatly the link supplied is'nt working, i wonder if it checked. eckythump.
  • eckythump Jan 20, 2009
    once again thankyou for your help, the link worked and have worked out from the manual where my connectors go which is fantastic but unfortunatly i dont no which way round the connectors go, ie positive & negative i think, there are two wires, one is coloured & one is white, on the connector blocks there is an arrow pointing to the coloured wire, is this the positive or + or is it the white, the manual does'nt explain and i'm not the best at this sort of thing, so if its not too much trouble i could do with another pointer. thanks eckythump.
  • 98 Answers
You can download the manual for your motherboard here.
Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
If you need any further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Posted on Jan 18, 2009
  • Nikola Malesevic
    Nikola Malesevic Jan 20, 2009
    I am truly sorry for providing you with the wrong link. FixYa does not support linking to ftp addresses and that is the reason why the link failed.
    New download link is located here.
  • Nikola Malesevic
    Nikola Malesevic Jan 21, 2009
    I have just checked the manual and there is information about where does each of the poles connect. Anyway, even if you have doubts, you can't be wrong. If you connect HD LED or Power LED incorrectly - they simply won't light up. And as for Reset and Power Buttons - they won't work. If anything's not working, just reverse. You cannot create a short-circuit.
    Please, don't forget to rate.
I need a manual for power sw, hdd sw ,led sw
hello are you trying to connect your motherboard to your desktop pc?
you will have to provide more detail on this as every motherboard is different.
if it is a modern motherboard the correct ports will be indicated on how to attach these to the motherboard and the leads from the desktop power, audio etc will also have these.
please provide more details of the motherboard.
Jun 15, 2011 | Intel Computers & Internet
My motherboard has fried: Albatron KM18G Pro 2003. It no longer seems to be available. For the computer to be exactly as it was before disaster struck, do I need exactly the same motherboard?
Well you do not need exactly the same motherboard. You need a motherboard that has the exact CPU socket, DDR slots and AGP or PCI slot.
Here are the specifications for the motherboard: Processor
- AMD Athlon/Athlon XP/AthlonXP Barton/Duron Processor
- FSB 200/266/333MHz
- North Bridge: NVIDIA nForce2 IGP
- South Bridge: NVIDIA nForce2 MCP
- I / O Chip : Winbond W83627HF
- 3 DDR Sockets:
DDR200 to 400 non-ECC DDR SDRAM up to 3GB (Single Channel) or up to 2GB (Dual Channel)
Expansion Slots
- 1 x AGP 8X/4X slot (1.5V Only)
- 3 x PCI slots (PCI 2.2 compliant)
IDE Connectors 2 ATA133 channels (up to 4 ATA 133 IDE Devices)
Onboard I/O Connectors
- 1x Floppy Connector
- 2x USB 2.0/1.1 header (4 ports USB cable optional)
- 1x CD_IN header
- 1x COM Port header
- 1x S/PDIF in/out header (S/PDIF in/out cable optional)
- 1x CPU fan header with fan rotation detection function
- 1x System fan headers with fan rotation detection function
- 2x 5 pin system panel header (Intel spec)
- 1x 3 pin Power LED header
- 1x 4 pin Speaker header
- 1x Front audio header (Intel spec)
- 1x Case Open detection header
- 1x Wake on LAN
- 1x 4 pin TV-Out header
So you have to buy a motherboard that has Socket A, that support DDR I memories and has an AGP slot (for the video card).
If you need further assistance, just leave a comment. Thank you for using FixYa.
Apr 19, 2010 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
My HP a420n was working fine.To replace the cd-rw drive with a dvd-rw drive I turned the computer off, removed the power cord and replaced the drive (I wore an anti-static wrist band). I then pushed the...
there is a possibility that you may have pulled off the power switch, to motherboard Connector.
This will be at the bottom right hand-side of the Motherboard.
You should have a 2 cable connector for. pwr/sw Power Switch. hdd/led Hard-Drive led. rst/sw reset Switch.
Check those First. if you didn,t remove the power lead, before attempting any work. you may have arced a current, and damaged the motherboard Or PSU. check the Fuse In The Actual plug lead. to determine the actual power Switch, without a multi-meter. remove the power lead, from the Computer. remove the power/sw connector From motherboard, And Bridge the power/sw with A plastic jumper Block. then replace power lead, and should boot up. If it does the fault is the actual power switch faulty.
Mike @ Compurepair.
Oct 22, 2009 | HP Computers & Internet
Want to connect my mercury PVM7 PRO MB
what type of motherboard do have? It sud be on right hand-side you will find some pins. USE MEGNIFYING GLASS THERE BE WRITTEN IN SMALL PRINT connect power LED, HDD LED, RESET SW AND POWER SW
Jul 28, 2008 | Computers & Internet
Reset/power/led etc..lead connections
on most motherboard it is possible to read there to set the wires.
hope this helped a little.
May 15, 2008 | Compaq Presario 5000 PC Desktop
Startek ST-693AVA/E front panel connection problem (22 pin block)
you can identify this in your motherboard but just in small letters, they are also written as RESET SW, HDD LED, POWER ON,
Dec 18, 2007 | Computers & Internet
hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
Aug 05, 2007 | EliteGroup P4M800PRO-M Motherboard
Albatron nForce2 KM18G Pro (KM18G PRO 2.0) Motherboard Logo
1,504 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
