Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Spectra TrueTemp Oven Pilot is Out
Just simply went out. Top burners are working but oven won't ignite. How can I either light the pilot light or re-ignite it?
Thank you in advance!
  • 11,896 Answers
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Posted on Jan 20, 2009
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
How do we re-light the pilot on the GE TrueTemp self-cleaning stove?
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 30, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    The oven doesn't come on-but the self clean and broiler work
    Check the electronic starter/pilot ignition on the bottom oven burner. It may be dirty, too far away from the pilot gas or the temp sensor on the pilot light flame may need replacing.
    Dec 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Getting to the Pilot
    Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
    Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Gas oven dosnt work
    the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
    Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    How to light Oven Pilot for Magic Chef stove 31000 PAW
    There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
    Nov 25, 2008 | GE JGRP17 Gas Single Oven
    GE XL44 Range
    The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
    Apr 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    1,516 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
