Question about Snow Joe Sun Joe Lj600e Logger Joe 5 Ton 2 Hp Electric Log Splitter
I'm dennis,i have the exact problem as denny *****. how do i fix it ?
I have an earthquake log splitter that the braker button on the machine trips shortly after i push the on switch. everything with the electrical is fine.
Works for 15 min and then ,the ram moves to log and stops,checked fluid ok, voltage 115 ok
My thought is that there is air in the line. I had problem like that with my splitter. To cure it I had to stand the splitter on end because the oil fill is at the wedge end. I filled it. set it back horizontal and cycled the ram full length 3 times. I stood it on end again and could add more fluid. When I filled again it was now full of fluid and works properly. It also could be that the splitter is not powerful enough to split that size log down the middle. I must take a smaller bite then it works.
Dec 13, 2015 | Earthquake 5 - Ton Electric Log Splitter
I have a bush A126Q washing machine which I have had one day & the start button has jammed. Does anyone know how to un-jam it or get front panel off? Thanks
If this is a new machine I'd advise you to contact the company-you may viod the warranty by trying to fix it yourself-cheers Denny
Oct 19, 2013 | Washing Machines
I have a wonder fire model 2610 and I need to replace the gas log set #500 2933 , please let me know where I need to go. Send reply to ss529@aol.com. Thank you. Dennis schnell
Dennis the Wonder Fire Gas Logs & Fireplaces are pretty much exclusive to Australia. So dealers there can probably help you. I have provided links to two different dealers that you may contact,
http://www.nectre.com/index.php?page=wonderfire
http://www.cradlemountainfireplaces.com.au/products/gas
I hope this helped you and thanks for choosing FixYa. Cheers
Sep 21, 2011 | Heating & Cooling
I deleted a message from yahoo email and i can't get it back. it was from patricia dennis
Confirm it's not in your trash bin. And if not there, the info is lost, you may as well make a way to get in touch with the sender (Patricia Dennis) for a re-send.
Best regards
Sep 13, 2011 | Yahoo Mail
I was cutting logs and pinched the bar on my johnsored. now the chain is loose, tried to tighten it all the way but wont tighten enough.goes to end of travel and makes clicking nose from tentioner worm...
Hi Dennis,
If you're getting a clicking noise from the tensioner assembly, yes replace it.
Also, after pinching the bar, a lot of times it gets bent. Put the bar on a completely flat surface and check for flatness. You might have to replace that too. :>(
Been there, done that... :>)))
Handie Andie
Jun 11, 2011 | Oregon Scientific Garden
My H P fax machine is telling me to push enter to
Hi Dennis,
You must replace all ink carts to get a sucessful alignment.
Dec 26, 2009 | Office Equipment & Supplies
Main control panel
Hello Dennis,
Welcome
You said, You have no leds on the front of the panel. When i switch on the machine all i get in the screen is 188 a snow flake top right of this and an 's' shape top left. Cant reset it holding down the right buttons. Any ideas anyone, is it time to replace it. thanks Dennis
I need the model number and year!
Waiting your response!
Huuum
Sep 03, 2008 | Siemens 24 in. SE25A266 ExtraKlasse...
Flashing lights
Hi Dennis,
All I can say is bugger!!! Sorry I couldn't help
Aug 20, 2008 | Canon BJC S450 InkJet Printer
Snow Joe Sun Joe Lj600e Logger Joe 5 Ton 2 Hp Electric Log Splitter Logo
Top Snow Joe Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Snow Joe Heavy Machinery Expert? Answer questions, earn points and help others
