Question about Amana ACO1840A Microwave Oven
Need to replace present microwave with compatible one (ACO18490A)
I need to totally replace the above model (which seems to be hard to find these days), with a compatible one, especially in size as it will fill the same space above the range.
  • 432 Answers
I guess you already done some microwave shopping and can't find anything. SEARS sells this item for $400.00 http://www.sears.com/sr/javasr/[email protected]@@@[email protected]@@@&BV_EngineID=ccifaddlfkfgdkkcefecemldffidfmm.0&vertical=SEARS&sid=I0004501420003900085&pid=02276779000
Posted on Jun 25, 2007
SOURCE:
Sharp carousel ii microwave
Turn table does not turn , sharp convection microwave R-9H84B
Can I fix this myself? or do I need to have it serviced?
Dec 06, 2013 | Sharp Microwave Ovens
Hello, I have a Panasonic MMT573SBBPQ microwave oven. 1. The turntable table stopped working. 2 Tested motor all OK 3. Noticed bulb had blown - replaced this (as was on same circuit as motor) 4. result :...
Check the door switch and once the door is shut the board must be active. If there is no clock or display then the processor board is faulty. Also if there is no action from the touch pad then it must be checked. Since the turntable works as you start the processor seems to work but the output to the magnetron is not active. So you need to check the relay to the magnetron switching, check the temperature cut off unit and the main capacitor.
All the above seems to be suspected.
Attempt with care/caution as there is high voltage present.
Aug 09, 2011 | Panasonic NN-H764 Microwave Oven
Roommate steamed up the spacemaker by hard boiling pot of soup without running the fan. Then microwaved a cup of coffee while the steamed condition was still present. An arc sparked from the vent above...
Sounds like a problem in the high voltage side. Need to check the diode and if good the voltage at the magnetron. Should be 3.5 volts across mag and 4500 dc volts at mag. If you do not have a meter to check replace both mag and diode aprox $150.00 from GE. Pat
Dec 03, 2010 | GE Microwave Ovens
Cookworks microwave model M7017NP-F need to know
As in most microwaves you have to remove the outer cover to replace the bulb.
Jun 19, 2010 | Microwave Ovens
Microwave lamp burn't out
You can find owner's manuals (which would cover any user-replaceable lights if present), installation instructions, and parts list, which have helpful exploded view diagrams here.
You can order parts here.
Jun 30, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Shelf support burned off
The shelf supports will need to be replaced. It's best to replace them all. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Before you install the new supports, you should clean the cavity squeaky clean in those areas where they mount. If any paint is chipped or charred, it should be sanded bare, then fresh high-temperature appliance paint should be added. That can be had from home improvement stores, or Wal-Mart, etc.
Sep 13, 2007 | GE JVM1490 Convection/Microwave Oven
Amana ACO1840A Microwave Oven Logo
187 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
