Question about Drills
How to install brushes in DeWalt 14 Volt DC970 drill
How do I install brushes in the DeWalt 14 volt DC970 drill?
4 Suggested Answers
  • 384 Answers
SOURCE: how do you replace brushes in a dewalt 18 volt
Why do you think the brushes are worn.
Posted on Sep 18, 2009
mark24354
  • 776 Answers
SOURCE: How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Posted on Mar 19, 2010
TDelect
  • 17 Answers
SOURCE: I purchased brushes for my
Brushes over time will wear down so comparing from the old to new will not look the same. If 18V brushes fit into the your drill then it should be fine.
Posted on Apr 06, 2011
How to change brushes on a dc970
I don't think the motor is serviceable that way. At
DeWALT DC970 Parts List and Diagram eReplacementParts com you can find the motor and pinion for $35 plus shipping and then get the entire drill working again. Had the same problem with one of mine and it was an easy fix.
Apr 10, 2014 | Dewalt 18v Cordless Hammerdrill Dcd970
Dewalt 18vxrp stopped working. Any suggestions???
Knock the back end against something. Or shake the drill and if it sputters, it could be a loose wire, or more likely worn brushes. If that doesn't do anything, open the case and check with a volt meter if you are getting any current past the switch (ie hold the terminals from the volt meter onto the brushes or onto the leads coming out of the top of the switch.)
If you get a reading of 19V to a couple volts less, then you're switch is most likely okay. Check for worn brushes. Or a motor replacement might be necessary. (Yes it's easy to do)
Apr 21, 2012 | Dewalt Dc987k2 Xrp 18volt 12 Drilldriver...
I purchased brushes for my 12 volt dewalt drill yesterday at the Dewalt warranty store in Denver. Today I took the housing off the drill and it does not have the same type of brushes in it as the...
Mar 24, 2011 | Dewalt DC727KA 3/8" 12v Cordless...
How do i change the bushes on my dewalt 18 volt battery drill
The brush holders are located at the back end of the motor. Depending on which model you have, you may have to only remove the end cap at the back of the motor to get access to the brush/holder set. Or you may have to split the entire clamshell to get at them. Be careful if you have to remove the transmission, there are a lot of small parts that can fall out and they all have to go back in correctly to make it work.
Oct 11, 2010 | Dewalt 18 Volt Compact Drill Kit
The chuck is stuck on 18 volt dewalt drill
It is not the chuck that is stuck, it is probably the armature. Probably a problem with the brushes. Since it is so easy I would try first unscrewing the caps and pulling the brushes out to see if things spin then. If the brush will not come out then it is probably jambed and you would have to take the drill apart. If you take the brushes out and still have a problem, at least one reasonable but simply checked problem is eliminated.
Oct 30, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt DWo56 18 Volt cordless impact
all drill has brushes. this particular drill you need a motor assy
or switch. vibration & heat are common problem cu'z the drill not to properly
Mar 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
43 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
