Question about Dell Dimension 2400 PC Desktop
Dell front panel power light abcd lights yellow
Monitor suddenly and randomly goes blank and front panel power light and abcd lights turn yellow
  • tenaj kaye Jan 12, 2013
    turns out i have bad capacitors on the motherboard, bulging and leaking, looks like time for a new computer.
  • Dell Master
  • 7,627 Answers
Does the monitor go out completely, no power? Or just lose a signal? Check ALL cables, AC and Monitor cables. Could be a Graphics adapter issue or Monitor , try another monitor.Your computer has a few miles on it , right? You could buy a PCI Graphics card if the monitor is OK.
Posted on Jan 02, 2013
  • tenaj kaye Jan 02, 2013
    monitor loses signal and abcd lights and front panel power light on tower turn yellow
    this happens randomly, while I am working on the computer after a few hours, seems to be getting more frequent.
  • 3278 Answers
SOURCE: Dell OptiPlex GX270 mini tower won't boot
Reinstall (remove and reinstall) your USB devices.
Could be memory error. Remove and reinstall your memory modules one at a time.
If not, could be your motherboard.
Hope this helps.
Posted on Aug 17, 2009
eagle338
  • 4889 Answers
SOURCE: Power
You might have to change your power supply..(ex:SMPS or ATX)
Posted on Oct 23, 2007
SOURCE: Power
check to see if something on the motherboard is fried, usually the capacitors are the first to go. look for swollen capacitors (the X on the top of the capacitor is not flat, usually leaking something or just swollen). If so, have the motherboard changed, if it's still under warranty, DELL replaces it for you.
Posted on Dec 10, 2007
edisonfrelan
  • 113 Answers
SOURCE: Monitor displays breifly then goes to blank screen
try booting up your CPU again, while on its process of booting press F8, then select (something MODE), okay, then when you are at windows environment go to control panel, select display, set your display settings its default or 900 by 600 pixels settings, then if its run okay then change to your desired settings.
Posted on Dec 17, 2008
  • 508 Answers
SOURCE: I have Dell GX280,I got the Solid Yellow light on
check connection on computer!!!
Posted on Jun 25, 2009
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
Dell REV A00 Monitor shuts off
Does your power light turn amber?
what about the lights on back the ABCD lights
do you have any popped capacitors?
Aug 10, 2010 | Dell Dimension 2400 PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Dell e172fp flat screen
check the power if 110 volt or 220 volt
Jun 05, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
Dell Dimension 2400 PC Desktop Logo
157 people viewed this question
Alun Cox
