Question about Targus 16 Metro Roller Notebook Bag. 16in Metro Rolling Laptop Case Nb-cas. 16 Screen Support - Polyester - Black
Replacement wheels for targus roller bag
Wheels and axel
How do you pack a bugaboo travel bag? It does not seem to fit with the wheels on?
You can find detailed instructions on at www.bugaboo.com/userguides but short the answer is yes the back wheels have to come off to fit in the bag. There's a simple wire spring you compress with your fingers where the stub axel fits into the frame.
Apr 05, 2011 | Bugaboo Frog Stroller
How do you change the rear tire on a 2008 Street Glide? gotta get it off the bike.........
1) Remove hard bags.
2) Use a marker to mark a position of the belt tension cams on the axel. This will help you put the proper amount of tension on the drive belt when you put it all back together. The left cam is welded to the left side of the axel. The cams are used to tighten or loosen the belt tension. You will see what I'm talking about when you get there and look at it.
3) Remove the two bolts from the rear of the left side bag support. Then loosen the front bolt of the bag support. (Remove the left fusebox cover to access the front support bolt.) Lower the bag support. This is necessary to slide the rear axel out.
4) Remove the two banjo bolts from the rear brake bracket and slide off from the rotor. Support brake with something so you don't damage the brake line.
5) Look carefully at the spacers on the axel and note, along with the order.
6) Loosen the cone nut of the axel on the right side of the bike, but don't remove.
7) Use a bike jack to raise the bike so that the rear wheel is barely touching the ground. Just enough that you can turn the rear wheel and feel the treads rubbing the ground.
8) Remove the cone nut from the right side, along with the right alignment cam washer
9) Genlty tap the end of the axel from the right side of the bike until it slides out from the wheel hub.
10) Pull the axel from the left side, take note of IDS washer and spacer order and position.
11) Slowly jack up the bike until you can pull off the belt pulley...that also contains the IDS (Isolated Drive Sprocket) NOTE; Check that damned IDS bearing in the drive pulley. I have gone through 4 of those crappy bearings...usually every 10k. If the seal is broken on the IDS bearing, get it replaced. This is the wicked gremlin of the 08 FLHX. The rear IDS pulley should just pull away from the hub at this point.
12) Jack the bike up until you can roll the tire, or get it out from underneath the bike. Did I tell you to strap the bike so it doesn't fall over? Just in case ya'know.
It all goes on in the reverse order. I never mount the tire on the rim...I have someone else to that and the balancing. Make sure none of the rubber isolators in the drive pulley have fallen out. Once you have the axel back in, tighten the cone nut enough so that you can tighten the drive belt by turning the cams from the left side of the axel. Use the paint marks you put on the right side of the axel cam to get the drive belt tension where it was at the time you started this whole process. Tighten hand tight, then loosen one full turn, then tighten the cone nut on the right side to torque specs. (Damn, I can't remember what that was. I think 90 - 110 foot pounds but I can't say that with certainty. I think the brake bolts are 35 to 45 foot pounds.)
Hope the helps. You can get cheap PDF shop manuals online if you look hard enough. The best investment I have made was a Harley Shop Manual for the bike...but they ain't cheap.
Feb 21, 2011 | 2008 Harley Davidson FLHX Street Glide
How do I attach the net bag to buzz 4?
Good Afternoon
Remove the front wheel by using the buttons either side of the front wheel unit and sliding it out of the chassis. Fit the front of the shopping basket on and now attach the back of the basket around the rear wheel axel using the velcro tabs.
Dec 28, 2010 | Quinny BUZZ 3 Capri Stroller
Replace the belt on a upright vac
There is a very small wheel attached to the motors drive. Belt goes around the motor drive wheel and then around the drive roller assembly
Feb 22, 2010 | Kenmore 34612 Bagged Upright Vacuum
Wheels are broken
If you can open-up the housing around the wheel(s), you can probably find replacements from a place that sells/services in-line skates. They're probably more durable than what was originally installed by the manufacturer.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "Very Helpful" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Dec 29, 2009 | Targus Port 3.1 Easy Roller
I lost a wheel - Where can I get a replacement? otherwise the bag is fine
You may want to try to go to your local hardware store and see if you can find a close generic replacement.
Home Depot and Lowes both have aisles with casters and small wheels, you might find something there that will suit your purposes.
Sep 23, 2009 | Targus Port 3.1 Easy Roller
Have Targus roller laptop case. Wheels have gone and cant find replacement. Any pointers?
My Port 3.1 bag had a bad wheel - called Targus customer support at 1-877-482-7487 and they're sending me replacement wheels with the hardware. No charge - this is being covered under warranty.
Aug 15, 2009 | Targus Port 3.1 Easy Roller
Subaru cv axle noise?
Do you know if this car has ever been recked? if your going thru that many axels makes me think something is not running true, a wheel bearing would not make a cv joint in a axel go bad. Did you replace the axels? or did you have them done at a shop, and did you see the old axels after they were replaced. You got bigger problems than a wheel bearing. From what i can gather some thing is bent or your getting bunch of bad axels witch i dought.
Feb 05, 2009 | 1987 Subaru Gl 4WD
Instructions for removing/replacing rear wheel, 2007 FLHR
remove the bags and side covers /remove clip from rh side of axel remove nut/put wrench on lh side of axel and twist to loosen belt adjustment caution !! note clamshell adjusters both sides they need to go back the same way when refiting wheel knock the axel from rh side through with large screw driver use hand not hammer the wheel should drop stand over back fender lift wheel slightly slip off belt roll brake caliper up and outwards untill it clears drop wheel down and remove brake caution again!! belt tension should be 10lbs 4.5 kg force centre from front and rear sprocket you will need belt tension tool for correct tension
Jan 18, 2009 | 2006 Harley Davidson FLHR Road king
Targus 16 Metro Roller Notebook Bag. 16in Metro Rolling Laptop Case Nb-cas. 16 Screen Support - Polyester - Black Logo
Top Targus Office Equipment & Supplies Experts
vojvodabudva
Anwarul Haque
Anwarul Haque
Are you a Targus Office Equipment and Supply Expert? Answer questions, earn points and help others
