Question about Acer Aspire T135 PC Desktop
Montior well the waves started after i unpuged the montior like the page is reloading
    Genius:
  • Acer Master
  • 1,102 Answers
Okay make sure your plugging the monitor back in securely
Either you need a new monitor or video card if what you are saying is correct did the video card in your system become lose
Posted on Jan 18, 2009
  • DEKR
    DEKR Jan 22, 2009
    unplug it then plug it back again
  • DEKR
    DEKR Jan 22, 2009
My 1990 lumina starts but when you give it gas it acts like it dies but when you let up on the gas it comes back. i have changed the brain box, the eec, and the exhaust senser, nothing worked.
have you replaced the map sensor or try unplugging the map sensor and see what it does also check the vacume hose or conection to the map sensor also try unpugging the throtle position sensor with either one unpugged you wont be able to drive it but you can see what it does parked
Sep 20, 2011 | 1990 Chevrolet Lumina
The sound has suddenly become garbled (sounds like an overdriven amplifier) on my g7-1075dx running Win 7 x64. AMD Phenom II P650, sound: IDT High Definition CODEC (date 12/17/2010 version 6.10.6319.0),...
Old PC AMD Phenom II Processor
W7-64
sound? (its was fine at day 1 too, and is not important to the cause
unless installed an OS not from HP media.)
why not say what you are doing. sound tells us zero.
  1. playing wav files.?(wave) "pure audio"
  2. playing mp3. or any of 50 other formats. do tell.?
  3. using only media player fails. or using vooduu player or boom?
  4. only on youtube.
  5. only when streaming, say netflix or? 50 choices?
  6. playing the system sounds in control panel fails?????
  7. speakers and phones both fail, and buds? if yes, its sound card software issues. (i bet)
  8. You do know if the system is virus infected this will happen right./ and if the startup folder is full of useless things any processor will overload, for sure this one.
tests
  1. systems sounds ok,? in CP./ control panel.? yes/.no
  2. can you play wav file locally, yes not.
  3. did you reload W7 using the HP hot key F11? reloads w7 to day one, and bingo works. (well , for some audio and some vids)
  4. did you reload all drivers. from HP,.? G7-1075dx
  5. did you as on the real HP forum and not here, (we are not HP so answers will be wrong most times)
  6. are you using USB head phones , now that it has its own sound chips in side that can mess-up the HP drivers badly. so unpug this thing,. learn to use real 2cable mini jack head phones for the HP, chips, or lean to use the sound icon on in the task bar nan tell the system you are not using , internal chips for sound, on my wifes pc we run both, internal and external usb. and must select them at the task bar icon speaker. (its tricky this) do learn that MS and HP do not support those USB phones. at all. means bad things happen. there.
  7. Old laptops. G7. HP dropped support on G7.
May 15, 2017 | HEWLETT-PACKARD HP G71075DX Pavilion...
I need Bose Wave Music system manual.
You can find manuals for almost all Bose products on the Bose website. Below find the link to the Wave Systems page. Select your model and you can view the manual in PDF form online.
http://worldwide.bose.com/productsupport/en_us/web/product_id_list/page.html#Wave®_systems
Hope this helps.
Jan 11, 2011 | Bose Wave Music System CD Shelf System
Why am i getting shock wave grashed
Go to http://www.adobe.com/ and download a new shock wave player, it's free.
Jul 20, 2010 | Google Chrome
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
Scroll pages they scroll in a wave pattern!!! Cann't play mobster
It sounds like you need to upgrade your video driver. This is a common problem when computers run off the default Windows driver. Probably best to go to the IBM website and get the latest video driver for your model and follow their instructions.
Nov 29, 2008 | IBM Computers & Internet
Need help
Some laptops need you to turn on the external montior conection in the bios
Oct 28, 2008 | Toshiba Satellite A135-S2246 Notebook
Black pages
I would try and turn the unit off, unpug, wait. Replug, switch on and try again. This sometimes resets errors. Post back if no go lilacgerry xxx
Feb 06, 2008 | Brother MFC 6800 All-In-One Laser Printer
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
Acer Aspire T135 PC Desktop Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
