Question about Home
KOHLER TOILET k4512aa k96
We are looking to match the color of this toilet that was installed in our house and not sure what part of the model number dictates the color
  • 659 Answers
SOURCE: Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
Posted on Apr 11, 2009
SOURCE: Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Posted on Apr 21, 2009
manhandy
  • 146 Answers
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
Posted on Jun 24, 2009
SOURCE: kohler lowboy toilet seat does not have bolts underneath
I have the same low boy where the bolts are inside the hollow body of the toilet. I called Kohler customer service and was told to use brute force to yank the toilet seat out. My husband suggested using a saw to cut the bolt but he hasn't done it yet. He wants to replace all our Kohler low boys which constantly leak becos of poor design of handle and flapper. The handle pulls the flapper slightly to the side when you flush. And the flapper lip being a tiny bit too small, if it doesn't sit just right, the toilet leaks. We've replaced one already with a Toto and love it. Too bad that Kohler isn't trying to fix the problem as I see many many online posts with the same problem and recommendation to replace the Kohler with Toto or somethng else.
Posted on Aug 09, 2009
Digglesby
  • 71 Answers
SOURCE: Kohler one-piece has no flushing power
Don't flush more water! Trash the toilet and replace it with a toilet that uses less water and flushes efficiently; practically every manufacturer makes a dual flush or eco model. Spend your money on a good toilet rather than paying for and wasting water every day.
Posted on Nov 04, 2009
I have a Koehler model 703 84679aa. The seat bolt is loose and you cannot get to the but without pulling the toilet. Does anyone know how to tighten the seat without removing the whole toilet?
Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
Jul 26, 2015 | Home
Where can I purchase a new Kohler 85330-cp-17 Teal replacement molded wood elongated toilet seat for our existing toilet?
You cannot. As you state, it is discontinued, confirmed on Kohler site.
If color is really important, consider painting it or a new replacement using an appliance epoxy spray paint such as Rust-Oleum after careful preparation of the surfaces.
Jun 13, 2014 | 85330-BR-17 Part - Teal Assembly Seat-...
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
Jan 08, 2013 | Porcher Toilet Seat Veneto 70030.071
I have a Price Pfister Marielle Kitchen Faucet that looks exactly like Model No. F-026-3NCC. I need to replace the ceramic valve so I ordered part #Price Pfister 974-035. It looks similar to the valve in...
That faucet was discontinued some time back for the one you ordered parts for and the only way to get the part if it is still available is to know the part number. Now if you have a plumbing parts house in your area that specializes in faucet parts they may be able to match up the old part if you still have it.
If you can find the part number for the faucet you have then the part may still be available from Price Pfister.
Mar 03, 2011 | Price Pfister Marielle Kitchen Faucet with...
My daughter did the experiment of putting food coloring in the tank, then, we waited an hour and the color was in the bowl. Is it true that this would signify a leak in the toilet?
That is a very strong indication that you need to replace the flapper. As there are a lot of different makers and types I would recommend you try to match it up or go with a universal repair flapper. When you are installing the new flapper check the sealing surface to make sure there are no rough spots that could cause a lesk. If there are you can remove all water from the tank and use medium grade sandpaper to smooth it up. I hope this helps you.Thanks.
Feb 17, 2011 | Sterling Home
I need to replace the flapper on my kohler model 703 toilet but don't know that part # can you give that to me please.
Kohler toilets normally have the part numbers on the underside of the the tank lid. I was not able to find the 703 model listed on the Kohler sites; check under the tank lid there for a more complete model number and possibly a specific number for your toilet flapper.
Here is a fairly user friendly site with an illustrated selection of Kohler replacement parts. You may be able to match your model number or measure and visually match a suitable replacement:
http://www.toiletexperts.com/index.php?main_page=index&manufacturers_id=12&sort=20a&filter_id=2
Your other option is to turn off the water supply to your toilet; remove the flapper and pay a visit to your local plumbing supply store. In some cases you will be able to use a universal repalcement part as long as the means of attachment and the size are the same.
Feb 05, 2011 | Kohler Home
I'm trying to locate a toilet seat that came on my Kohler toilet and as part of this process I need to identify the Kohler color name, part number if applicable, etc. Can you please help me identify ...
If you are in Minneapolis call Ferguson supply,they are the kohler rep. I think they might be national.Good luck with that part,don't think they go back that far.Overhead issues,numbers are familier but could be tough.
Jan 26, 2011 | Kohler Home
My kohler k4663 toilet seat broke. where can i find inexpensive model numbers from other manufacturers that would be compatable
I believe the code 47 on kohler is the Almond color. If you special order the Brevia(cheapest) model from Lowes, I remember it being in the 20s or 30s... Many places don't carry this color in stock as they like to carry white ones. Bemis (aftermarket company) carries seats that fit kohler as well. Call your local store and see which one is cheaper.
Dec 01, 2010 | Kohler K-4663-47 French Curve Toilet Seat,...
Home Logo
93 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
