Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Starting hard cub cadit with 14 hp onan starts with holding hand ovver carb but runs fine after but when restarting have to do the same thing
  • 608 Answers
Hi Ted, most likely the choke is not coming on fully. To fix this adjust the choke cable or if the choke is on the throttle adjust the throttle cable. Regards Phil.
Posted on Jan 01, 2013
  • ted dodson Feb 26, 2013
    this didn,t help runs and staars with air cleaner off but won,t withit on and with laod on air cleaner on it boggs down and quits but without it it runs fine
5 Suggested Answers
  • 7 Answers
SOURCE: my riding cub cadet won't start. key clicks,
jump start it from your car, the battery is dead
Posted on Jun 08, 2009
  • 3 Answers
SOURCE: the mower is a cub cadet it usually runs fine
I had the same problem , found out it was the coil was getting hot. I replaced the coil which was not hard , remove 2 screws an unhook 2 wires. You have to get the coil from a dealer , in my area anyway. Hope this helped.
Posted on May 06, 2009
  • 25 Answers
SOURCE: 2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Posted on Jun 22, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
My onan 4.0 generator will not idle and is back fireing while trying to run it will run fine for ten min then starts trying to die and starts back fireing when I try to keep it running
check for a faulty sump oil switch . check for faulty coil ( magneto on the flywheel) as the time it runs suggests that it is breaking down internally.
Feb 11, 2015 | Onan CUMMINS 4.0 KYFA/6747 - Cummins...
Our onan generator ran out of gas. we refueled but the generator will not start. i gave it a shoot of starting fluid, the generator fired and run for a second, then died. could it be a cogged fuel filter?...
No, not the filter, you will need to try to prime the carb better then with starting fluid, pour some gasoline down the carb, you may have to do this a few times, but everything will fire back up again once you get the air out of the system
May 25, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Jun 07, 2009 | Watts Onan Portable Generator - 4000 ,...
The mower is a cub cadet it usually runs fine until warm and will die start idling up and down and then die every now and then pop like back firing.it will start right back if you lift the choke i changed...
Apr 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
Try to restart to see what happens. However, make sure to have a volt meter to check output voltage. You may be loosing voltage and therefore it shuts down. Check oil pressure switch, rings, brushes. Replace brushes if they are less than 1/2" short and clean rings with emory cloth until copper is noticable.
Jan 21, 2009 | Watts Onan Portable Generator - 4000 ,...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
192 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
