Question about Gateway E-4000 PC Desktop
Im having problems finding half hieght agp card for my e 4000 gateway
My computer has no 3d capability and can not support google earth im having trouble finding a half height video card - the gateway e 4000 does not allow for regular size cards because of the height of the cpu cover is too short _is there an external solution ?
  • Gateway Master
  • 4,806 Answers
Hi.
Yes you will need a half height AGP graphics card for that tower. You can purchase such card from places like eBay or Amazon. I suggest you get something over 128MB. Click on the link below for an idea.
http://www.ebay.co.uk/sch/i.html?_nkw=half-height+AGP&_sacat=0&_odkw=hp+6735s+keyboard&LH_BIN=1&_sop=2&_osacat=0&_from=R40
Good luck and regards.
Posted on Jan 01, 2013
shadow5599
  • 51 Answers
SOURCE: Video card upgrade
Relevant link
Yes it does have an AGP slot, which you can confirm easily by looking at the motherboard. The AGP slot would be found at the top of the available slots and is brownish in color and slight smaller than the several white PCI slots.
As for what card to put in, that depends on your budget and needs.
If you're a gamer, spend as much as you can and go with a N-Vidia based AGP card.
Please rate this as solved once you've read it, unless you have further questions, then post another comment.
Thanks!
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Posted on Oct 18, 2007
  • 214 Answers
SOURCE: video card for the gateway 507gr
The 507GR had onboard video - so when you insert a new card you will have to deactivate the onboard video in Device Manager.
As regards the replacement card - any modern card will work fine, what you need to know though is whether your motherboard has an AGP riser or will accept PCI cards.
I have been told that PCI Express graphics cards are preferred over AGP cards, but I don't know why.
Good luck.
Posted on Apr 23, 2008
SOURCE: Motherboard - disable onboard graphics
1. open your cabinet.
2. remove the battery form the motherboard.
3. wait 15 seconds and then replace the battery again.
4. connect your screen to the pci ex card.
now it should work.
CS
Posted on May 15, 2008
Amardeep46
  • 129 Answers
SOURCE: screen goes on and off
This is a well known issue with gateway media centre and there is no easy solution for this problem. If you are an expert in tearing apart the system and putting it back, then this LInk has some options which have worked to many people.
Posted on Feb 01, 2009
  • 123 Answers
SOURCE: Upgrade video card
Any of the cards here are suitabl,e with almost all under $100 and are all PCI Express x 16
Your mobo is not suitable for the PCI X 2.0
Remember the amount of memory on the video card comes from your available ram - so you need to consider this when buying if you dont have much ram.
If you need more help deciding let me know
Posted on Apr 20, 2009
Need agp video card
buy one generally off craigslist or ebay, since its a gateway and doesn't have a very big power supply you're going to be limited in you're choices of video cards. Generally a geforce 7300 agp would be a good choice for budget minded.
Dec 30, 2012 | Gateway E-4000 PC Desktop
When loading and using Real Flight Basic, I receive the following message:" Video card dooes not support shaders. Now exiting program." Question: Where is my video card and what card must I replace...
Shaders are usually found on higher end video cards. If you are using the nVidia FX5200 that came in that system, you can try updating the drivers to the newest ones you can find, but more likely you'll need to upgrade to a better AGP graphics card...one that has 256MB to 512MB of RAM onboard. You'll want to research the card of choice to see if the shader function is available. I don't recall that FX 5200 having anything more than Shader 2.0 capability, but you need to make sure your DX9 and the driver for the card are up to most current.
Dec 12, 2017 | Gateway 510 X (10272197) PC Desktop
Cantfind driver for my prophit 4500 64meg agp
download from here
http://drivers.myfreewares.com/freedownload-631-guillemot-hercules-3d-prophet-4000-4500-4800-display-driver-16.055-winxp-download.html
Oct 11, 2009 | Guillemot 3D Prophet 4500 TV/Out (64 MB)...
What video card would be compatable with a insignia computer model d300?
I would recommend any of the Nvidia or ATI video cards that come in the PCI format. Your computer only has PCI slots. These are the older slot types, so your options will be limited for brand new cards, but there's still plenty out there. As long as the slot type is PCI and the chipset is a major manufacturer, it should work with no problem. Do NOT get any video card that says "PCI Express" or "PCI-X" - they won't fit.
Jul 18, 2009 | Insignia Computers & Internet
When i try 2 starting IGI game....a problem popon up.... ''d3d driver with hardware acceletor not found'' give me solution.... anurag yadav... anu_infoleon@yahoo.com
Either you do not have a graphics card with 3d capability or you don't have the driver installed. To find out goto start > Settings > Control panel > System > Hardware tab > Device manager > Click plus on display adapters. Either google the driver listed there or post it here as a comment and you can find out if it has 3d capability. If you don't have a 3d able card many motherboards allow the addition of a 3d graphics card as an upgrade.
Jun 11, 2009 | Computers & Internet
Ev 700
you must attatch agp(accelareted graphics port) card in pci slot it is specially for 3d games and excellent video output fast motion responce but if you want to see normal ordinary display then no need of agp card
Oct 27, 2008 | Gateway EV 700 17" CRT Monitor
Xfx gforce 6200 graphic card
try reinstall the google earth after complete uninstall taht happend when connection is droped or some files r missing
plz do aret this post
Oct 07, 2008 | XFX GeForce 6200 Graphic Card
Problem playing certain games
driver wont matter buddie that mx 400 aint made for games ok upgrad eyour card to nicer one to play alot new games what kinda slot u have pci or agp
Jan 07, 2008 | Gateway GeForce2 MX400, (64 MB) AGP...
Graphics Card is not supporting Direct Draw
ensure your mainboard is capable of 8X AGP speed. also try to re-install video drivers.
Aug 18, 2007 | Nvidia WinFast GeForce4 MX4000 128MB DDR...
Compaq s4020WM AGP Questions
I don't think there's a 8x AGP card made that would not work at 4x, and any 4x capable AGP slot should handle an 8x card. AGP 1.0 (x2) signals at 3.3V AGP 2.0 (x4) signals at 1.5V AGP 3.0 (x8) signals at 0.8V
Apr 05, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Gateway E-4000 PC Desktop Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
