Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need part that goes on top of 15 Inch L7 subwofer
3 Suggested Answers
Jim1969pa3
  • 152 Answers
SOURCE: i have two 15 inch L7 Solo-Baric Subwoofers and need an amp
I would recommend a brand named class D amplifier.
Connect both woofers in parallel (Positive to positive, and negetive to negetive) in a sealed enclosure. Make sure you have no air leaks. By connecting them in parallel the combined impedance will be two ohms. Make sure that the amplifier you choose can handle a load with that low of a resistance. Any high end amp should do this. Buy as much power as you can, but I would say a minimum of 1000W RMS. Beware of cheaper amps advertising "peak power". This can be considered half of what the RMS power would be (1200W peak = 600W RMS approximately).
Next, Run very heavy gauge (zero guage if you can) power line directly from the battery. Protect the wire where it passes through the body with a rubber grommet or otherwise something to keep the metal from cutting into it, and PUT A FUSE IN. I cant stress that enough. Put an 80 amp fuse in line incase you have an accident. Otherwise your car could very well burn!
Want even more punch?
Back at the amp, install the largest stiffener capacitor you can afford 1 Farad or bigger. Install this in a space where it would be protected in the event of an accident (on the inside of the strut tower or somewhere above the axle). There is a whole lot of energy stored in there that you don't want unleashed on you!
If you have any other questions please ask away!
Posted on Apr 13, 2009
etirbynnor
  • 655 Answers
SOURCE: need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Posted on Jul 16, 2009
@aol.comI have a kicker zx 1500.1 amplifier and a 15 inch L7 2ohms. Is the amp too much for it?
the amplifier is never to much for the sub. If the gain on the amp is turned up to much then that will pop the sub.
Jul 30, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Two questions. 1) can my amplifier over-power this sub; kicker L7 15 inch dual voice coil 1,000 watts RMS wired for 2 ohms? 2) is my amp too small for this sub-woofer? thank you for your time.
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
Apr 08, 2011 | Kenwood KAC-9103D Car Audio Amplifier
I have a kicker 15 inch L7 solo baric and the rubber piece around the plastic part of the center of the sub has come apart from the outside black ring. how can i fix this?
You can purchase a silicone sealant set, specifically for speakers. Its quite easy to use. Ebay has alot of them and they are relatively cheap.
May 03, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a 2004 toyota corolla would i have enough air space for for to l7 15in or im i better off getting 12's
you have enough air space for 1 L715 or 2 L7 12s the 12s will move more air and hold more power than 1 L7 15 inch sub
Jan 27, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I need a 15 inch single box
3.4 cubic feet
Tuned at 40 Hz
2 Ports = 4" x 8.25"
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 04, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Db drive vs kicker
The Kickers are the way to go here- they move more air because naturally a 15 inch square has more area than a 15 inch circle- thus more air moved =greater spl =LOUDER. The only thing that might get some equality between the two is if the db drive round sub has a far greater xmax that is the linear movement of the cone from start to full excursion-IF the db drive has drastically larger xmax than it could possibly outperform the L7 because of greater cone excursion which also =more air moved=louder---- haha thats a tricky one but ya got me wondering too so let me know what you find out please-Ive always been a kicker fanatic so im probably biased towards their products-never heard nothing bad about db drive though either im in salt lake city i dont know of anywhere out here that even carries their products so i have nothing to reference by except kicker L7's kick asssssssssss
May 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
